Question about C-Technologies C-Pen 800 Handheld Scanner
I need a power cord for my c-pen and I am at a loss as to where to get one. I have looked all over the net and I need help getting a Y power cable. Thank You carol kittson
I forgot my password
Reset the modem by removing the power cable from the back of the modem for a full 30 seconds and plugging it back in.
This is sometimes referred to as "power cycling" the modem, and is a good way of clearing network timeouts and other problems that can appear on modems that have been running continuously for some time.
Reset the modem by unplugging the power cord from the electrical outlet or surge protector into which it is plugged.
This is a good alternative to removing the power cord from the back of the modem if it is difficult to get to the modem because of its physical location. Count the full 30 seconds and plug the modem back in to complete the reset.
Reset the modem by pressing the reset button the back of the modem.
The button itself is recessed into a hole to prevent accidental resetting, so you will need a pen or some similar thin utensil that can fit inside the hole.
Press the pen into the hole until you feel the button depress and then let go.
This is sometimes called a "hard reset" or "hard reboot," as this will restore the modem to its factory default settings
Hope this helps
Sep 25, 2012 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Bad power cord or bad connection on laptop?
Probably the DC Power Jack which is where the power cord plugs into the computer. Take a ink pen and stick the tip in where the power cord goes to see if it wiggles. If so, that's your problem.
Mar 31, 2012 | Dell Inspiron Mini 1012 Netbook
I'm trying to g wireless and when I unplug the ethernet wire I get a message " local cord disconnected" and on the wireless connection it day's "limited or no Internet use"
you need to first reset the box by unplugging power cord. It should power up with your regular settings. If not, then hit the reset button in the very back with a paper clip end.
Next step is launch your AT&T Self support using att.net and your ID/PW this will look at your router for you. YOu will need the two sets of codes on the underside of the gateway/router box.
IF still no action, use the ATT.COM/.NET chat line. its very good and they can self test for you. Calling the help line is not very helpful, use chat.
Jul 16, 2011 | AT&T Computers & Internet
I need a power cord for a Tournament Master HR Bottom Line fish locator. Where can I find this cord?
Do you still need the power cable? I have a new unopened power cable.
Dave
Feb 10, 2011 | Boating
Damaged power cord
The power supply AC adapter power cord is the same as used for PC power cord, local PC repair shop should have them.
Or you are looking for the AC adapter is 12v 4A power adapter, try Ebay
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 13, 2010 | SVA-USA 9005B (Black) Monitor
Have loss of signal...have power...brief flicker of screen then total black...any idea of problem?
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Princeton monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
May 19, 2010 | Princeton Digital VL1716 17" LCD Monitor
I need a replacement power cord
Found one here:
http://acebargains.stores.yahoo.net/acpoadforwel.html
and ebay looks to have a few as well:
http://cgi.ebay.com/AC-power-adapter-Westinghouse-LCM-17V2-sl--LCD-monitor_W0QQitemZ360118562836QQcmdZViewItem
Hope this helps. You are right this far from a typical power supply cord. Most just need to the cord with a 3 hole female end that plugs straight in the monitor.
Mar 02, 2009 | Westinghouse Computers & Internet
Acer 3690
Once you get the pin repaired be sure and use some sort of cable stay or restraint so it doesn't happen again. . .
Here's something I recommend. . .
Mar 20, 2008 | Acer Aspire 3690-2196 Notebook
Power cord HELP
Power cord is almost impossible to find! However, you can purchase a charger for the lithium battery itself!! Good luck
Oct 30, 2007 | Samsung SC-D372 Camcorder
C-Technologies C-Pen 800 Handheld Scanner Logo
26 people viewed this question
Top C-Technologies Office Equipment & Supplies Experts
jasbo
jasbo
Are you a C-Technologies Office Equipment and Supply Expert? Answer questions, earn points and help others
