Question about Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor
What does error code C2 11 mean? - Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor
    Scholar:
  • 122 Answers
Code 11 means there is not enough gas
is this a new install?
do you have at least 3/4" gas line to the unit?
Posted on Aug 31, 2010
  • zandar3 Aug 31, 2010
    also, check to make sure nothing is blocking the vent. if you have exhaust gasses coming back through the intake into the unit, it will shut down and give that same code.
  • drdaveyo Aug 20, 2011
    DON'T EVER BUY THIS UNIT.....THEY ARE JUNK
What is code blinking 20 on noritz tankless hotwater heater N_069M
The error is a HIGH LIMIT THERMAL ERROR. That means Calcium buildup has appeared in the unit. It is also called scale. To clear the error you have to power it off. That is done by the circuit breakers. You should descale the unit first though.
Jul 26, 2014 | Noritz Water Heaters
What does error code 13 mean?
1) Copy following links for Rheem tankless error codes
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Tankless-Error-code-13.pdf
2) Maintain water heater as shown in product manual to avoid common error codes.
Dec 28, 2012 | Rheem EcoSense by 7.4 GPM Tankless Water...
Tankless water heater model # RTGL74PVN is blinking 38 what does this mean
Copy following link for general troubleshoot and error codes:
Error code 36 does not show in any resource, including 2008 service manual, or 2012 product manual.
Check that remote control display is illustrating the correct number.
For example there is error code 35.
Oct 19, 2012 | Rheem Tankless Hot Water Heater...
What does code 36 mean
Error code 36 does not show in Rheem tankless manuals.
Copy following link for general troubleshoot and error codes, and Rheem contact information:
Oct 19, 2012 | Rheem Paloma Tankless Water Heaters...
Rheem model 41vrp40n flashes twice and stops working
Error code means that you have electronic gas control valve.
Copy following link to identify gas control valve, read error code meanings for each, and download service manual relevant to each gas control, but not specifically Rheem since rheem does not post service manuals.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
The fact that water heater restarts, means that water heater is getting gas, getting sufficient air for combustion, thermister is ok, gas pressure is good, etc.
The fact that you unplug and replug water heater and it works, shows that you have power vent model.
Since water heater worked correctly before, 2 flashes with Rheem power vent model could mean that pressure switch has failed.
Jul 29, 2012 | Water Heaters
My water heater shows error code c-4 it starts for 3-4 min then stops. what does this code mean?
Before calling service technician, open following link for Rheem error codes, chat, and possible solution:
Error codes are start-point for troubleshooting.
C4 11 can mean no ignition:
Simple solution for this problem can be to clean burner and combustion parts including sanding any carbon deposits off of iginiter.
Other simple things can be loose wiring on gas solenoid, or improper grounding, or low gas flow or gas pressure.
Other causes can be bad gas solenoid, bad igniter, misaligned ignition parts and sensor, bad igniter wiring.
As you know from reading your product manual, tankless require yearly service. This service can prevent many common error codes before they happen.
Typical do-it-yourself maintenance can be accomplished using following pdf
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Sep 16, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
No hot water error codes 76, C4,C7
Before calling service tech, open following links for Rheem troubleshoot resources including rheem chat, error codes, possible maintenance and service manual.
Error codes are considered start-point for troubleshooting.
Multiple error codes can mean PC board failure.
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
http://waterheatertimer.org/pdf/Error-code-13.pdf
Aug 12, 2011 | Rheem RTG-66DVN Direct Vent Natural Gas
Remote is flashing C8 and 76, alternating. I turn the unit off, then back on, and I get hot water for about 10 seconds, then it goes cold and the same error message occurs. Unit is Rheem Main Remote...
Before calling service technician, open following links for Rheem tankless resources including error codes and Rheem chat.
Disconnect wires from remote to see if system stabilizes. Unit will heat to default temperature without remote.
C8 76 can mean PC board failure.
76 can mean communication failure with remote control
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Jul 31, 2011 | Rheem Tankless Water Heater Main Remote...
Getting error code 16. what does it mean and what
a 16 error code is typically caused by scale formation. I'd recommend performing a descale on the heater.
Mar 06, 2010 | Noritz 6.9 Gallon Residential Direct Vent...
Error code 21 A1
This means the air intake cover problem.
21
Malfunction of Air Intake Filter Switch Ensure air filter door is properly seated. Ensure front panel is properly installed.
Error codes here: http://www.palomastore.com/paloma_error_codes.html
Mar 03, 2010 | Rheem Paloma Tankless Water Heaters...
Rheem Paloma PTG-74PVN /  RTG-74PVN Natural Gas Indoor Logo
549 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
