Question about Asko W600
Where can i buy a motor for the Asko w600 in Ballarat
  • Asko Master
  • 713 Answers
Hi just read your posting.Now the place to buy all spare parts for ASKO washing machines is in MELBOURNE. Asko has their factory in Moorabbin.If you ring up directory assistance and ask for Asko"s phone number they will provide it.Then you can buy the motor over the phone and it will take a couple of days for delivery.Unfortunately I do not have the phone number off hand.By the way why are you replacing the motor,maybe I could help with the problem.Please reply to let me know how you got on.Looking forward to your reply.
Posted on Aug 28, 2010
Asko W600 extra rinse button not working
some can be taken apart and inside is a spring loaded connection that pushes the button back out sometimes hard water and soap and debris can jam and stick the spring and u get what ur getting? you may be able to by pass the extra rinse by disconnection the prongs to it and taping them up?
Mar 29, 2015 | Asko W600
Washing machine does not heat up
ITS NOT SUPPOSE TO HEAT UP THE WATER COMES IN HOT FROM THE OUTLET? THE WATER TEMPERATURE SWITCH DETERMINES WEATHER IT USES HOT OF COLD ECT
Feb 24, 2014 | Asko W600
Asko w600 front load washer did not spin water out of clothes. I emptied the drain pump and now it fills with water but doesnt wash the clothes. The water drains out but nothing else. Help
Check to see if your model has a "out of balance" micro switch.
If it's tripped from you moving the unit around you may have to reset it manually. It will be mounted somewhere close to the outer perimeter of the tub. Can't say exactly where. Could be high or low.
Jul 11, 2012 | Asko W600
I have an Asko W600 front load washer that does not spin water out of clothes. It fills, washes, empties but does not spin- skips this part.
Hi
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the door lock-switch assembly. If the door lock-switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 15, 2011 | Asko W600
My ASKO W600 slowly fills with water after it has completed the wash and spin cycle. The machine is 5 - 6 years old and runs perfectly otherwise. How is the water inlet controlled to the machine? Can there...
hi yes you need to replace the inlet valve you have dirt in it,remove the top panel you will see the triple valve.its very easy to replace,
Jun 06, 2010 | Asko W600
Electric door release stopped working
does it not have a manual door release pull next to the filter
Aug 05, 2009 | Asko W600
Machine wont stop filling with water, it just overflows. Machine is an Asko w6551 front loader
Same thing happened to my ASKO W600.  Sounds like the water inlet valve is blocked or broken so therefore can't stop the flow of water coming into machine.  Check it out and replace if necessary.
Oct 30, 2008 | Asko Washing Machines
Asko W600 spin cycle not working
Check the brushes oin the motor. It's the most normal fault when this problem appears. Not a big thing to fix for a technician!
Sep 24, 2007 | Asko W640
Washing Machines Logo
110 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
