Question about Hitachi 53UDX10B 53" Rear Projection Television
53UWX10BA what did you do to fix it?
  • 927 Answers
Good Day, securestuden;
The first thing to do is to figure out what the TV is doing OR not doing.
Good Luck, big IRISH.
Posted on Aug 25, 2008
Hitachi 53uwx10ba service mode
are you using an HDMI cable? is it a cheap thin cable or heavy duty?
HDMI cables carry sound but it's possible you don't have it seated completely or it's a cheap cable. or your audio settings on your TV are not set to HDMI if that's the cable you're using. try running your audio setup on the TV Menu.
Dec 03, 2013 | Televison & Video
Hitachi 53UWX10BA HDTV with convergence problem for blue
No there are no quick fix options for this fault. The convergence amplifiers operate similar to a high power audio amplifier, so if there is an impairment anywhere in the system, it will result in distorted audio, or in the case of television convergence amplifiers, a color won't align. The convergence power pacs need to be replaced and the out of tolerance precision resistors located near the power pacs need to be carefully checked and replaced as necessary.
It is also possible that there are root faults that cause the amplifiers to go bad which include bad connections or a bad digital control module. This repair is possible for anyone having basic electronics knowledge and soldering skills.
Apr 28, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53uwx10ba turns on & off when off red flashing light/clic
Same problem. Replaced both convergence ICs about 5 months ago. Worked fince since then and just recently no sound, no video, blinking red on front panel and clicking sound. I suspect that the ICs went bad again and blew a resistor or two. I used cheap Chinese ICs instead of the Sanyo ones and thing this is why. I'll be looking at it again and post solution.
Jan 21, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Hitachi 53UWX10BA separated colors.
replace the convergence ICs you can get replacement ICs at the following link with free installation instructions. Use two STK392-150 ICs they are good durable ICs for your model,
Heres the link.
http://servicemanuals.vstore.ca/
Jan 17, 2009 | Hitachi 53UDX10B 53" Rear Projection...
DOUBLE LETTERING/RED
Good Day, TYREKCURRY;
Your TV is ONLY 7 years old, it's only half way through it's life. It will cost about $550.00 depending area. Repair Convergence Circuit FOR .5k or buy new TV for 1.2 k? I would get TV fixed. The HIT is a great TV. Get an estimate from a Factory Authorized Service Center B-4 repair> Good Luck, big IRISH.
Sep 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
53uwx10ba hitachi
only one click?
any blinking lights?
Jan 08, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Green lines along top of Hitachi 53UWX10BA
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 02, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi Mo# 53uwx10ba double image
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
  • Screen looks 3D
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Dec 03, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Problem in Hitachi 53UWX10BA
The convergence ic's, and related components that could'be affected need to be replaced cost to repair 250.00 2hrs job max with alignment this depending on the tech. If you need more help let me know
Jun 14, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
41 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
