Question about Scotsman Refrigerators
Dce33 ice machine running but timer seems not to work,,,any quick fixes
  • Scotsman Master
  • 3,740 Answers
I saw the chat be declined it hoping your question would pop up here. It did so here goes. If the time is not advancing you test for voltage on the timer motor terminals. You should read input power at the terminals. Then check for resistance from each one of the terminals to the clock motor. There is a switch on the back of the timer motor that stops the timer at the end of the harvest cycle. The switch can be bad as in stuck with the switch actuator depressed.
See page 22 of this manual for the switch on the timer motor:
http://www.abt.com/images/products/PDF_Files/DCE33_om.pdf
There can also be a problem as noted inthe service manual:
Caution: The timer is controlled by the cube size
control, and will not turn if the cube size control
does not work.
The cube size control can be defective.
Your machine is supposed to cycle every 25 minutes.
Here is yet one more link that gives some great information about icemaker troubleshooting:
http://www.achrnews.com/Articles/Service_and_Maintenance/dd0baaf2a87bc010VgnVCM100000f932a8c0
One more comment about the cube size control under troubleshooting:
Cube size control will not close:
1. See “Too much heat load” or
2. “not enough refrigerant” (low freon)
3. Control defective - must be
replaced.
Thanks for choosing FixYa.
Kelly
Posted on Aug 28, 2010
Scotsman ice machine DCE33
if it's plugged in and you didn't trip a breaker, the switch in the timer has been known to go
Jan 21, 2014 | Kitchen Appliances - Others
Scotsman icemaker dce33 is making ice, but it is melting
Yes it could and also check dump valve it should not let water through during freeze cycle.
Oct 03, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
My Scotsman undercounter icemaker is not producing much ice and the little it does produce is watery. How do I fix? The model # is DCE33PA-1WB. Is this model discontinued?
Wow! That the first time I saw one of these! Never even knew they made it under
counter types.Anyway I'll give it a shot,Let's see here It's not producing ice as it should huh? I Googled it for complaints and found this for you,Linda go to
(http://www.retrevo.com) and once you get there type in (Scotsman DCE33)
into site search engine and it'll list service manuals for your model to seek a fix.
It stated how to make maintenence adjustmments ok now good day!
Jan 02, 2011 | Scotsman 15" Luxury Consumer Ice Machine
I have a new DCE33 scotsman ice machine. No spray small flow
Could be in need of cleaning with some nickleguard ice machine cleaner. Or maybe a restriction in the pump? How about a scotsman repair manual?
I have both. Hope this one is it
Nov 05, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Brand new Scotsman DCE33 ice maker melts ice
Check that the condenser is clean, the plastic sheet is hanging over the opening and trhat both spray nozzles are in place.
Jun 19, 2009 | Scotsman DCE33PA1SC 15in Built-in...
No accumulation of ice
Check to see if your condensor coil is clean, use an air compressor or other source to blow thourgh the coil,dont just brush it off. newer refrigerant charged systems need as much air flow as possible to work ,also make sure the cover is on the condensor section while the ubit is in nrmal operation. try setting the cube size to lowest setting and let run for 24 hrs. Let me know if you need further assistance.
Nov 16, 2008 | Ice Cream Makers
DCE33 Ice Machine
I believe it was the inlet water valve that needed to be replaced, but I got so fed up with the noise and repairs on this machine that I purchased a Whirlpool ice maker. So far, it's been great. It is much more quiet and produces 50 lbs of ice in 12 hours and shuts off until some of it melts. It only produces more ice about four times a day as it melts.
Sep 27, 2008 | Refrigerators
Scotsman dc33pa ice maker
Make sure the curtain is not torn and there are no leaks from the resivoir. If ok check to make sure you have enough water pressure to the machine. Make sure you have enough water passing through the valve during harvest cycle. To check... turn the timer cam to harvest cycle. Water should come in quickly behind the curtain on the right side and the timer should advance three minutes to freeze portion of cycle and stop running. Water should spray and form ice for approximately 25min. Then the timer advances for 5 minutes into harvest cycle and it refills with water again.
Nov 21, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
Refrigerators Logo
352 people viewed this question
Top Scotsman Refrigerators Experts
john h
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Scotsman Refrigerator Expert? Answer questions, earn points and help others
