Question about Craftsman Garden
How to order a new blade for my 18" hedge trimmer model no 315.796630
    President:
  • Craftsman Master
  • 1,545 Answers
My HS 45 seems to drip oil while cutting, I think it is damaging plants. Is it because there is too much oil in the fuel mix?
Fuel mixture for that model is 50 to 1. Stihl also sell their own premixed fuel and oil which is Ethanol free and non aromatic.
I wondered if it has a blade oiler, but it doesn't. I does however have a gearbox with oil in it. I wonder if it is leaking. Do you know where the excess oil is coming from?
You model is listed here and the Manual and details of the fuel are on his page.
STIHL HS 45 HomeScaper Series Hedge Trimmer
Oct 04, 2016 | Stihl Hs45, Hs 45 Hedge Trimmer 450mm 18"...
The blades won't move on my black And decker 40 volt hedge trimmers. It sounds like the gears are not turning
How To Repair Jammed Hedge Trimmers - SelfGrowth.com
www.selfgrowth.com > Articles > Spirituality > Self Knowledge
The frequent use of powered hedge trimmers poses the risk of the blades becomingjammed (and it is highly likely that this will happen to your model at least ...
Fixing a Hedge Trimmer - YouTube
? 3:15
https://www.youtube.com/watch?v=aMddbl9B0iE
Jul 23, 2011 - Uploaded by Joby F. Randrup
Ever had a hedge trimmer break because you hit a fence or something ... HEDGE TRIMMER REPAIR "how to sharpen hedge trimmer blades" ...
Nov 04, 2015 | Garden
I have a petrol hedge trimmer TRY26PHTA. The engine will start fine but the blades will not move
If the engine starts 'fine" then it has not seized.
Many, if not most, hedge trimmers are , for safety, equipped with a "CENTRIFUGAL CLUTCH" between the engine and the blade to prevent blade operation unless the engine is at full RPM.
IF your machine is so equipped, it's possible that the clutch is worn and slipping so badly that the blade can't move.
Jun 11, 2014 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Stihl HS45 hedge trimmer runs fine, blades move well, does not appear to cut hedge - what could be the problem ?
Dull blades! Lol, or they're not meeting eachother on each reciprocating stroke so there is no shearing action, much like a pair of scissors. Check to see if the blade bolts are too loose or is the blades are warped or if the cutting edges are simply too dull
Sep 24, 2013 | American Gardener Rh25 18" Readyhedger...
How long should a fully charge battery last on WG250E Hedge Trimmer
This is the info i found on WG250 battery . It says up to 50 min below in the features. Hope it helps
Battery
The WORX WG250 hedge trimmer incorporates an 18-volt 1.7 Ah Ni-Cd battery pack. You can use this battery pack with other WORX Ni-CD PowerShare tools. The included charger takes about an hour to restore a dead battery to full charge.
Cordless Hedge Trimmer 18v Worx WG250E jQuery(document).ready(function($) { $("a[rel=product-image-gallery]").fancybox( { 'transitionIn' : 'elastic', 'transitionOut' : 'elastic', 'titlePosition' : 'over', 'titleFormat' : function(title, currentArray, currentIndex, currentOpts) { return 'Image ' + (currentIndex + 1) + ' / ' + currentArray.length + ' ' + title + ''; } }); });
Features
  • Wall mount bracket
  • 3 position adjustable front handle
  • overmould soft grip for user comfort
  • Quick release handle
  • Double insulated
  • Volts: 18
  • Blade length: 510mm
  • Cutting capacity: 14mm
  • Blade action: Dual
  • Run time: Up to 50mins per charge
  • Charge time: Up to 1 hour
  • Machine weight: 3.1Kg
  • Comes with one battery and a charger
Sep 13, 2011 | Worx Wg250 20inch 18volt Cordless Hedge...
Think we need new blades for our cordless hedge trimmer. Where can I get them??/
Try the place where you made your purchase. If they don't have them in stock...Maybe they can order the correct blades for you. If they are not a Black and Decker dealer. Try on Line at their website.
Oct 06, 2010 | Black & Decker Hedge Hog Cordless Hedge...
Cutting blade for 8124-04 Type 5
Do not try and replace the blade.
They are not ment to be replaced let alone even resharped
If it can not cut any more time to buy a new model
Jul 21, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
My hedge trimmer blades do not move when I turn it on
Check the power wires that connect to the motor. My 18 inch B&D hedge trimmers both had loose wires at the motor that had to be re-soldered. You will need to open the trimmer casing to get to the loose wires, if that is the problem.
Jul 09, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
Electric Hedge trimmer will not cut
more than likely it damaged the inner gears or drive pins that make the blades reciprocate and need replaced. if you would like instructions to repair it yourself i will send you them or you can take it to a service center.
Sep 08, 2008 | Electric Hedge Trimmer, 18"
Garden Logo
57 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
