Question about Vacuums
No power is coming in. plugged in, will not turn on. last time i used it, it would go on/off. if i bumped or hit it, it would turn back on. can this be fixed by a fair novice, or trash it?
  • 377 Answers
Sounds like a loose wire or contact of some sort. Might be a bit too much for a novice to tackle.
I would start by UNPLUGGING the unit and try to get at the ON/OFF switch to see if there is a wire loose. If no loose wire is found I would trace the wire to the motor to see if there is a break in the cord, cut in the cord, etc.
Doing electrical work like this could be dangerous for the uninformed and may take some special equipment. Depending on what you paid for the unit, you may have to decide to pay or a repair or toss it.
WHATEVER YOU DO, MAKE SURE THE UNIT IS SAFE FROM ELECTRICAL PROBLEMS THAT COULD HARM YOU!
Posted on Aug 29, 2010
Why does the power brush turn on even when turned off?
If it is 6 months old, it should be under warranty. Call wherever you purchased the vacuum and ask how they handle warranty claims.
May 15, 2015 | Vacuums
How do you fix a red Hoover windtunnel 2 rewind pet vacuum (model UH70830)? Since me and my 1year old corgi have arrived at my moms place, I've been using her Hoover vacuum cleaner off the hook because...
It sounds like there's a problem between the power cord and the vacuum cleaner itself. Remove the power cord check the connection at the vacuum cleaner and see if something came unconnected
Nov 18, 2014 | Vacuums
Bissell quickwash 1970E for carpets/hard floors won't come on
If the burning smell was like rubber burning it is probably the belt. If you only used it a few times I suggest bringing it back to place of purchase. A belt should not go after just a few times of use. Besides if anything is burning after just a few uses I would return it.
Mar 28, 2014 | Bissell Vacuums
Motor won't start
Most times this will be caused by one of 3 items, the cord, the switch or the carbon brushes in the motor. Inspect the plug area on the cord for strain twist it gently and look to see if the cord appears a bit white where it meets the plug or if the cord appears crushed just before the plug.
Also inspect where the cord meets the body of the vac for the same signs of wear or any locations where it may have been caught in the power head , etc.
If you have test meter, check for resistance change at the plug while twisting and finally try the same twisting with the vac plugged in if necessary but keep your fingers back from the plug in case the cord blows... gently twist and pull slightly to see if the motor continues to run.
Most often when a switch fails it just dies and doesn't become intermitant... so with a meter it will generally test good or bad , nothing else..
Sometimes on a well worn vac when the motor doesn't start the carbon brushes in the motor have worn down. A heavy duty motor such as the Rexair can often be rebuilt if brushes are required.
If you turn the machine on and bump or jolt the side of the body as if to spin it, you can often "trick " the motor into starting. If this happens it is most likely a carbon brush issue , if not time for a new motor.
Rainbow/Rexair machines have a fairly good motor however because of how they run drawing moist air through they often rust as they age. This is a tedius rebuild and best left to a pro shop with parts on hand if requiring brushes. Most shops will simpley scrap a worn motor if rusty and replace it completely.
Before you spend big $ on a repair or replacement....
One last thing....... pull the exhaust cap at the back of the vac. You will seen fine powder dust and residue.Wipe your finger across it. This is what the Rexair releases into your home each time it runs, but you don't smell it because it comes out in the form of humidity...like after a spring rain.
That same humidity is rusting your motor gradually year by year. Although this motor has a long life span, consider that you have been breathing dirty humidity as it runs. If you put orange drink crystals in the water bucket and run the vac, the exhaust air would smell like orange juice,... so what is in the tank comes out in the air, including your dirty water.
Most Rexair owners buy thinking they are helping to reduce allergins.. yet what is on that exhaust plug proves otherwise. If your home is essentially carpet free and you are vigilant maintaining and rinsing the bucket, you might consider rebuilding this vac.. Otherwise consider a good High end European vac like a SEBO,MIELE, Nilfisk etc for better filtration and reliability
Oct 10, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Vacuum turns itself off or won't turn on
Sounds like a bad on/off switch or a loose connection somewhere in the vacuum. If you can remove the switch, you can see if any connections are loose. The switch itself can be checked if taken out of the circuit and tested with a meter or a continuity light.
Otherwise, you might want to consider a repair shop.
Mar 29, 2009 | Kenmore Progressive Bagless Upright with...
Roomba 415 bumps into something 3 time, stops
Txs for not helping me out unless I pay for it!!!! :-(
Jan 02, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Kirby vacuum problem
I suspect the safety/power switch. When nozzle is on the Kirby the protrusion on the nozzle casting must press the switch on the front of the unit (circled in red in the pictures below). See if that protrusion is not chipped off. It may be that a hook or even both are damaged (circled in blue) so nozzle is a bit loose and when you bump something it nozzle moves just releases the switch enough to shut the vacuum off. Hold the nozzle and try to move it. See if it is loose on the unit or not.
It could be the faulty switch too.
Nov 03, 2008 | Kirby G5 Bagged Upright Vacuum
Won't turn on; no lights, no power.
Did you try a different outlet? The cord may have gone bad, most of the times I find that people don't pull the plug out of the outlet by the plug, they just pull the cord, or it got yanked out some other way and that will break the wire inside the cord. Other then that, it would have to be taken apart to find the problem.
Apr 24, 2008 | Electrolux Epic 6500 Vacuum
IRobot Roomba Discovery not moving across room.
I had the same kind of problem with my model 400 today...after starting it and having it go in a circle for 30 seconds or so it would finally run into something and then back up a few inches, turn, then go forward a few inches, then back up a few inches, turn, then go forward a few inches, etc., etc.. I tried cleaning off the four pairs of sensors under the bumper and blowing out various things underneath (by mouth since I didn't have any canned compressed air). It didn't really help. It then occurred to me that I had a leaf blower! I put the Roomba upside down on the grass, put the leaf blower on high, and blew at it from all directions and up close. More dust came out than I thought would. It has been running normally now for the last 45 minutes.
Sep 26, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
Vacuums Logo
15 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
