Question about Mtd 46" Dozer Blade, Fits All & Yard - Man Lawn & Garden
Starter rope snaps back, yanking it out of your hand and does not start
    President:
  • Mtd Master
  • 1,545 Answers
Either the compression release isn't working properly and the valve lash needs to be adjusted or it has broken,or....the timing of the motor is off due to a possibly sheared flywheel key.
Posted on Aug 29, 2010
Tecumseh troubleshooting
Sounds like your flywheel key is sheared. The rope snaps back and almost rips your arm off. Definitely your key.
Aug 13, 2014 | Garden
Starter rope is broken how do i replace it
Remove the fuel tank and starter cowl, remove snapped rope.wind the pulley to put tension on the spring approx 7-8 rotations. Put a screwdriver through gaps in pulley and through a gap in top of cowl in order to stop pulley from releasing tension. Burn end of new rope and twist end with a rag while still hot to make a point at end ( careful not to burn yourself) then feed the pointed end through rope hole on outside of cowl and through the hole in side of plastic pulley. Tie a knot in the rope once its through and on inner of pulley. Fit starter handle to other end of rope.hold rope and remove screwdriver and slowly feed rope back into starter
Jun 19, 2013 | Briggs & Stratton Garden
Lawn mower starts then dies
sounds like ur timing gears have jumped a cog or two. That's the gears at the crankshaft to the camshaft. Pretty big job if you don't know what you are doing.
Apr 24, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
When trying to start engine rope yanks back
Likely the flywheel key is sheared or partially sheared. It needs replaced. The flywheel is under the recoil starter. The flywheel key usually gets damaged by having the blade impact a hard object.
I hope this helps you.
Aug 17, 2011 | Tecumseh Garden
I have a honda gx390 13 horse engine I just put a new pull Rope on it and cleaned the carb its been sitting for 3k10 years when I pull the rope slowly it will turn the engine when I give it a good yank...
This is a common problem. The valves need adjusting in the motor. You may eventually get it started and running in this condition but you will probably end up breaking your pull rope a few times in the process. Take it to someone who works on small engines like a mower repair shop.
Apr 01, 2011 | Garden
I have a 1200w ust portable generator and when I went to start it the cord it the cord snapped. What tools do I need and how do I replace it?
You do not need any special tools but you do need a third hand somtimes to complete the job.
Here are the basic steps after you remove the starter from the engine:
Prepair the new starter rope by burning the end to keeping it from fraying and shape it into a point. Use a rag to shape the point because it will be very hot. (about 5 feet of good qualty starter rope size to match existing. It is sold in sizes form about 3.5 to 6.5) Tie a temp knot on the other end of the new rope. Remove the old rope and align the hole in the spool with the hole on the starter cover and practice incerting the rope thru the guide hole on the cover into hole on the spool . This will be the final action after you wind the spool. You should be able to hold the spool and insert the rope thru both holes and tie a knot while holding the spool in a wound state. Once you have mastered incerting the rope thru both holes and tying a knot you are ready to begin.
Wind the spool in the same direction that the spool turns when you pull the rope. You must wind in the correct direction or you may bend the rewind spring out of shape. The spool will begin to tighten as you wind and will eventually stop turning when the spring is fully wound. Once fully wound unwind spool one full turn and stop when hole on spool aligns with hole in cover. Now insert rope as practiced thru both holes and tie knot with free hand or have helping hand. Once knot is tied slowly let spool take rope in untill no more will go in or you reach temp knot. Now tie pull handle and you are done. Good luck
Jul 29, 2010 | Briggs and Stratton 073001 2" Portable Gas...
How to replace starter cord on a victa corvette 400 series mower,cord snapped,i put it back on....now it doesnt retract properly when trying to start it
Not sure what engine that machine uses but they are all similar, you need to prewind the reel before you slip the rope thru the hole, let the spring/reel pull the rope in.
Nov 15, 2009 | Garden
Pull rope broke
This usually happens at the most inopportune time. You go out mow the lawn, pull the rope and it comes out in your hand. Here's how to fix it yourself.
First, we'll talk about a simple rope replacement. In most cases you will have to remove the blower housing from the engine to get to the underside of the rewind starter where the rope is. We'll assume at this point that the spring is ok and you can just wind it back up again. You can check the spring by turning on the hub in a counter-clockwise direction and see if the spring gains tension. Do not try to remove the spring from its holder or you may end up having to take the mower in for service.
1. Remove the rope from around the hub. Since there is no tension, it should come right out. If you are lucky and it broke near one end, you can probably just re-use it. If it is badly frayed or too short, you will need to find a replacement at a local hardware store.
2. Attach the handle or tie a knot in one end of the rope so it will not wind all the way into the hub. You also may want to burn the rope ends to keep them from fraying and causing a problem in the future. Set the rope aside where you can grab it once you wind up the spring.
3. Wind the hub in a counter-clockwise direction using your thumb to keep it from unwinding, until the spring is tight. Then let it come back slightly so the rope hole in the starter housing lines up with the rope hole in the hub.
4. Stick the rope through both holes while holding the hub from unwinding. This is tricky because you don't want the hub to unwind on you before you have the rope secured in it. A pair of needle nose pliers or a small screwdriver or pick may help get the rope through.
5. Tie a half hitch knot in the rope after you have it through both holes. While holding the rope, release your hold on the hub and let the rope slowly pull itself back into the starter.
6. Put the blower housing back on and your ready to start the engine & mow.
Kurt
Mar 15, 2009 | Garden
Rope snapped in my recoil starter..
take off the and and turn the coiler on the inside a few turns and when it starts to get tight put a screwdrive through it so it wont spin, put the rope in the hole and bring it out and tie a knot. the turn it gently to release the screwdriver and let it coil the rope back in
Jan 13, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Mtd 46" Dozer Blade, Fits All  & Yard - Man Lawn & Garden Logo
59 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
