Question about Ovens
I have an elgento e452 halogen oven, need cooking instructions.
Need to replace fan on my elgento e452 halogen cooker
Posted on Jan 06, 2012
3 Suggested Answers
rickead1
  • 1998 Answers
SOURCE: can i down load a
Do you happen to have a model number? Thanks again Rick
make and model usually always help for us to be able to find what your looking for message me back
Posted on Jan 21, 2011
BarrettDenCo
  • 1772 Answers
SOURCE: can you cook stews in
yes you can
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 22, 2010
Two of my Hotpoint EW95 Halogen Double Oven elements have lost temperature control. When switched on they go to full heat and stay there regardless of setting on dial. What is wrong?
change switch if there is no control if talking cook top elements
Infinite switch burner control need model number in full for quote
Nov 18, 2014 | Hotpoint Ovens
NATURAL GAS OVEN WONT COOK PROPERLY
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Apr 06, 2014 | Frigidaire Ovens
Can i down load a cooking manual for 'quest halogen oven' if not think i will return for full refund. whats the use of oven without a cooking manual
Jan 21, 2011 | Ovens
Should halogen light keep going on and off when cooking
I wouldn't think that is typical of operation...
at what interval? (time wise)
Could be the bulb is loose, there is dirt around the connection, the bulb may be on the way out (how old and used is the bulb?)
Best regards
Ck
Jan 17, 2011 | Ovens
Can you cook stews in halogen oven
yes you can
Dec 22, 2010 | Ovens
We have recently purchased a Coopers halogen oven. I cooked a frozen fruit pie in it and the pastry looked beautiful, but when it was cut open the middle was cold and the pastry under the fruit not cooked....
Frozen food should be defrosted before cooking in halogen ovens.
Halogen ovens use only radiant heat and will not cook the centre of frozen food.
Jan 21, 2010 | Ovens
I Lost the instructions for my GE profile Oven probe. Need advic
I need oven probe instruction and oven conversion time with the convection oven for cooking a forty pound turkey.
Nov 25, 2009 | GE Profile JT952 Electric Double Oven
Clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Apr 28, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Instructions for delay cook timer
Here's the link where you can get the owner's manual with instruction's,
http://www.maytag.com/support/manuals_literature.jsp
Apr 05, 2009 | Maytag CWE4800A Electric Single Oven
Ovens Logo
429 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
