Question about GE DBXR463EDWW Electric Dryer
Okay-so far NO ONE -even at Sears-has been able to tell me what is wrong with my dryer-this is what happens-I can dry my clothes-but if they sit in there for more than 30 minutes after drying they become damp-the lint trap is catching lint but somehow there is a ton of it beneath the trap in the housing and it is sopping wet-at times the lint trap and that whole area will be so wet I can't get it dry with one towel-I disconnected it from the exterior hose and it is blowing-went outside and watched-there is signifigant air moving through-any one else know what's up with that? I was told be an employee it is a fire hazard, but no solution offered, I need some insight here.
    President:
  • 3,074 Answers
I would say it is the vent hose, you can buy the hose that has like a trap on the end, in other word you will not need to run it out through a wall. Since you indicated that there is a lot of wetting under the lint trap in the bottom of the dry...I would venture to guess that something is loose and not full connected to the back of the dry where you hook up the vent tube. all you have to do is take the front door/panel off and look at the tube running from the trap to the back of the dryer. Hope this helped tim
Posted on Aug 28, 2010
  • 1 more comment
  • pollykilmer Aug 28, 2010
    I will definitely try that and let you know. Thank you for the response, is this something you've ever even heard of before-so far it would appear that I am the only person to have ever had this weirdo problem!
    Umm, btw-how do I take the front door panel off?
  • Tim Whalen Aug 28, 2010
    when looking at it with the door open...you will see some screws unsrcew them and I believe on the bootom there may be two in each corner. then with a flat tip screw driver in the top corners it is clipped down gently pry upward and pop them loose. Of course make sure the machine is unplugged. Hope this helped Tim
Takes 4 ever to dry clothes. Will run & run when on auto dry.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jan 09, 2011 | Amana NDE5800AY Electric Dryer
My kenmore dryer heat element goes on and off. The clothes take hours to dry.
It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Dec 31, 2009 | Kenmore Dryers
Tumble dryer will not dry
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
Aug 19, 2009 | Dryers
Our model medt5870tw0 maytag dryer does not dry properly
First , remove the vent hose from the dryer to see if good air flow is coming out the dryer vent . If not , could have a bad blower wheel . If so , then check the vent hose AND vent to outside to see if blocked . A dryer will either heat or not heat . Since your dryer heats , try drying a load without the vent hose connected to the dryer and see if it heats fine (telling you , a vent problem is apparent . Sometimes a dryer is pushed too far back , kinking the vent hose also .
Aug 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer has to be run repeatedly to complete one load. shuts off before clothes are dry. is this a sensor issue, and how is it replaced?
Aug 05, 2009 | Dryers
Dryer not turning off when clothes are dry (model LDE 400ACL)
Normally if you have an automatic cycle that turns off the dryer when the clothes are dry, it will do it with a special thermostat or moisture-sensing system. The thermostat tells the dryer to heat until the interior of the dryer reaches a "pre-set" temperature.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. If there is a moisture sensor, the timer advances only if the moisture content of the clothing is low enough. The timer advances until the interior cools, then the termostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But... if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix this problem, clean the vent and/or internal ductwork and make sure the vent is not compressed or kinked. If that doesn't work, then your thermostat, moisture sensor or timer could be the culprit.
Jul 15, 2009 | Dryers
Dryer will not turn off
May 20, 2009 | Dryers
Gas dryer wont trun off after drying
May 08, 2009 | Dryers
Takes too long to dry or keeps running when clothes are dry
May 07, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Dec 01, 2008 | LG DLG5932W Gas Dryer
GE DBXR463EDWW Electric Dryer Logo
57 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
