Question about Whirlpool GR563LXS Kitchen Range
Have a whirlpool elec. range model gr563lxs. Iwas using the oven and when I was done, I went to shut it off and it wouldn't respond. I tried shutting the power off to it for a while, but when I turned it back on, still none of the buttons worked (clock, oven, temp, ect.) the cooktop burners still work, but none of the fancy buttons behind the glass work (looks kind of like a touch screen). PLEASE HELP!!!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with try to take the panel out and blow some air with the help of hair dryer so that in case there is any moisture inside it’ll blow it off. If still it won’t work then you’ll have to replace the Electronic Range Control (ERC). Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 28, 2010
Have Whirlpool electric range super capacity 465 with accubake system oven will not shut off
Karen, We are sorry to hear about your Oven. We are happy to look into your concerns but we will need your your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Jun 12, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
Double oven that lost power and will not reset and comes up with F o3
Hi and weclome to FixYa, I am Kelly
The oven temp sensor has failed. When the sensor fails the range control unit shuts off the oven. However..... this is a double oven an it should only shut off the oven with the bad temp sensor. If it got super hot...while you were using it and it themally protected itself you may also need a thermal fuse / high temp fuse. IF you can locate the model number and respond here, I will look your model up and see what may have happened.
(I tried to answer your chat but it had already been passed to another expert)
Thanks for choosing FixYa,
Kelly
Apr 20, 2011 | Whirlpool Microwave Ovens
Oven does not heat
This clicking sound.. If it is coming from the control panel area could be indicative of a relay that is malfunctioning.
For giggles try the oven on just broil. See if the upper element comes on and stays on, or if it too shuts down.
If it stays on then you most likely have a bad control board.
If it shuts off like the bake element and does not come back on, I would carefully inspect your power cord and cord connections as well as the range outlet.
Jun 16, 2010 | Kitchen Ranges
How do I change the light bulb in my Whirlpool range oven - model RF262LXSQ 2 - I've tried unsuccessfully to turn the lense in either direction, I'm afraid if I try harder I'll break it.
Re: Difficult to get protective cover off of oven light.
I had the same problem until I out on a rubber kitchen glove.
The adhesive properties of the glove allowed me to turn it off with no problems, but only after I messed with it for 15 minutes prior to noticeing a pair of kitchen gloves under our sink.
I hope this helps someone else. Kevin Gildart
Apr 18, 2010 | Whirlpool GR563LXS Kitchen Range
My Whirlpool oven fan is running continuously. This happened after the elec. co. shut the power off to change out a pole. We have reset the breaker twice but it is still running. In addition, it locked...
sounds like the electronic oven control has failed. you might check with the electric company to see if they will cover the repair(they usually have insurance to cover this). I have done work before when this type of thing happened and the electric company did pay for it. It is worth a shot.
Dec 18, 2009 | Whirlpool Accubake RF362LXTT Electric...
I have model GS563LXSS...all of a sudden the oven
It is not good to do the self clean. The electronics take a beating. Probably the ignitor went out. The oven gets too hot.
Nov 03, 2009 | Whirlpool GS563LXSS - stainless Steel Gas...
Electrical fire in stove
I would call the gas company and have it checked out in case you had a gas leak on the stove which may have brunt the wires , it safe with the gas and elec off,
Jan 04, 2009 | Frigidaire FGF326AS Gas Kitchen Range
Whirlpool Gas Range E2 F3
I HAVE A WHIRLPOOL GAS RANGE MODEL NUMBER SF379LEMS.OVEN WILL LIGHT UP BUT AFTER TEN MINUTES IT WILL KICK OFF ANF ON ON ,THEN AFTER AWHILE I WILL JUST SHUT OFF.ANY SUGGSTIONS. ADAM
Nov 23, 2008 | Whirlpool GS470LEM Gas Kitchen Range
Whirlpool SF315PEPW1 oven/broiler won't work
whirlpool range/over the broiler works the oven does not warm up. what is the solution.
Oct 24, 2008 | Frigidaire FEB24S2AB Single Oven
GR563LXSS Error Message?
merkatt123 If you just bought this range it is under manufacturer warranty. Do not do anything. Call Whirlpool for service. Gendos
Feb 18, 2007 | Whirlpool GR563LXS Kitchen Range
Whirlpool GR563LXS Kitchen Range Logo
93 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
