Question about Linksys Wireless-G WRT54G Router
Can't get encryption to work on linksys G WRT54G
  • Linksys Master
  • 7,733 Answers
Access linksys wireless-g wrt54g with Nook tablet
Change the wireless network name and then change the key.
Try to connect to the new wireless network and see if that works.
If not then you can try to upgrade the firmware of your Linksys router.
After upgrading the firmware, reset the router and reconfigure it.
Jan 01, 2012 | Linksys Wireless-G WRT54G Router
I forgot my password for my wireless router, and can not sign my wifes new phone up on our wifi
When your phone asks for the password, out in the Encryption key. If you didn't print this out when you installed the router, insert the CD and install the Easylink Advisor, which wil then show up down in your taskbar in the bottom right corner of your screen. Open it, click on the Support tab, and it will show all your settings. For the password requested on your smartphone, enter the encryption key from your settings in EasyLink Advisor. That did it for me. Good luck!
Oct 22, 2011 | Linksys Wireless-G WRT54G Router
Hallo! my computer do not accept the router. I set up many times but nothing is working with Wlan. in otherside, the internet ist working via broadband - Linksys(INTERNET) - Linksys(port 1) - Computer. It...
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
May 09, 2011 | Linksys Wireless-G WRT54G Router
Can only connect 2 computers
Yes, the Linksys Wireless-G WRT54G Router will used to connect the computer wirelessly by using the security keys.
You will have different combinations of encryption or security keys.
Jan 22, 2011 | Linksys Wireless-G WRT54G Router
I'm having trouble accessing my Quickbooks Online through my router model WRT54G
That is common problem, try to reboot your router as a temporarily solution. This router has weak stability when network is overloaded, check for settings related to traffic filtering and turn them off, any redirects, any firewall rules. Or make clean reset for the router and check will it work on basic WPA encryption setup only.
Jun 02, 2010 | Linksys Wireless-G WRT54G Router
How do i set up the encryption on my DI-824?
in the adress bar type 192.168.1.1 and that will bring up ur router settings
Dec 22, 2008 | Linksys Wireless-G WRT54G Router
Conection problem
If you are using the highest level of encryption available, your laptop may not support it.
back up the configuration file then reset it and set it up to be used without any encryption then see if that works.
If it does then the encryption is your problem, this is only the case when using WPA 1 or higher.
Dec 14, 2007 | Linksys Wireless-G WRT54G Router
Setting up a WAP54G as a wireless repeater with a WRT54G
Requirements for WAP54G & WRT54G Repeater Mode function: * WRT54G: Firmware 2.02.2 or higher * WAP54G: Firmware 2.06 or higher Go to http://www.linksys.com/download to download the latest firmware upgrades for both devices. . Accessing the Router?s Setup Page: Open a Web Browser (either Internet Explorer or Netscape). 1. Type the IP Address of the Router into the Address Bar (192.168.1.1 is the default IP Address). 2. Click GO or press the [Enter] key. The User Name and Password prompt will appear. 1. Leave the User Name field blank. 2. Type admin in for the Password (the default Password). 3. Click OK or press the Enter key. The Router?s Setup page will open: * Click on the Status Tab. * Click on the Wireless sub tab. Write down the Wireless MAC Address and the Channel number values located on this page. If the Encryption Function is Disabled, go to the WAP54G Repeater Setup section below. If Encryption Function is Enabled: Note: WPA (Wi-Fi Protected Access) is not yet compatible with wireless repeater mode. You must use WEP Encryption if you wish to use security options with this configuration. To gather WEP encryption information, click on the upper Wireless tab, then the Wireless Security sub tab. Write down the Passphrase. WAP54G Repeater Setup Be sure that you have the WAP54G plugged directly into one of the WRT54G?s numbered ports for the duration of the setup. Accessing the WAP54G?s Setup Page: Open a Web Browser (either Internet Explorer or Netscape). 1. Type the IP Address of the WAP54G into the Address Bar (192.168.1.245 is the default IP address). 2. Click GO or press the Enter key. 3. The User Name and Password prompt will appear. 4. Leave the User Name blank. 5. Type in admin for the Password (the default password). 6. Click OK or press the [Enter] key. The WAP54G?s Setup page will open. 1. Set the Channel value to the same channel as the WRT54G router that was obtained from earlier steps. 2. If WEP encryption was enabled on the WRT54G: * Select Enable for the Wireless Security option. * Click on the Edit Security Settings button and enter the same Passphrase as the one of the WRT54G router that you recorded. Click Generate to populate the WEP key fields. * Click Save Settings to save your changes and close the encryption window. Click Save Settings to save your changes on the Setup page. 3. Next, click on the AP Mode tab. * Select the Wireless Repeater option. * Enter the WIRELESS Mac Address from the WRT54G that you recorded. (Disregard the fact that the page asks to ?Enter the LAN MAC ADDRESS?). Click Save Settings to save your changes. Close your web browser. You can now place the WAP54G Access Point in another nearby location (with its power adapter plugged in) so that it can repeat the wireless signal that it receives from the WRT54G. Notes: * The ?SSID? of the WAP54G does not have to be the same as the WRT54G. This can be used for initial configuration; using a different SSID will enable testing of network connectivity, and will show that the WRT54G is associated with the WAP54G. * If MAC Filtering is configured on the WRT54G, no extra configuration is needed. Wireless clients will still need to be added the MAC Filter list of the WRT54G, but the WAP54G does not have to on the list.
Feb 16, 2006 | Linksys (WRT54GC) Router
Linksys Wireless-G WRT54G Router Logo
19 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
