Question about Epson Office Equipment & Supplies
My epson stylus NY415 does nt move so that I can put in ink. (the cartridge cover)
    President:
  • 4,070 Answers
Hi! Please try this. Unplug the printer from power source then press hold the power button for 10secs. while the printer is unplugged to reset the system. After 10secs. plug the printer, turn it on and see how it goes. Hope this helps and thank you for using FixYa!
Posted on Aug 28, 2010
My printer is not recognising the replacement ink cartridge although I've used these before many times
If you have just installed a new cartridge and you still see an ink related error, the cartridge may be incorrectly installed. Follow these steps to make sure the cartridges are correctly installed:
  1. Make sure the Epson Stylus is turned on.
  2. Do one of the following:
    • If your printer indicates that an ink cartridge is expended, press OK.
    • If your printer does not indicate that any ink cartridge is expended, press Setup, select Maintenace, and press OK. Then select Change Ink Cartridge and press OK.
  3. Open the scanner.
  4. Open the cartridge cover.
    Caution:
    Never attempt to open the cartridge cover while the print head is moving; wait until the cartridges have moved to the replacement position.
    To avoid damaging the Epson Stylus, never move the print head by hand.
  5. Press down all the ink cartridges until they click into place to make sure they are properly seated.
    Note:
    If a cartridge is properly seated already, you may not hear a click.
  6. Close the cartridge cover and press it until it clicks into place.
  7. Close the scanner.
  8. Press OK to begin charging the ink. This takes about 2 minutes.
    You see a message on the display screen when ink charging is finished.
    Caution:
    Never turn off the Epson Stylus while the ink is charging or you'll waste ink.
If the issue persists, it appears to be an issue with the cartridge(s). Contact Epson for further assistance.
Sep 25, 2014 | Epson Stylus DX8400 All-In-One InkJet...
I just replaced all my inks and it is still telling me to replace my cartridges i also turned it on then off
  1. Open the scanner.
  2. Press the cp_button_14.gif Stop button to move the cartridges to the replacement position.
    Caution: Do not move the print head by hand; this may damage your all-in-one. Always press and release the cp_button_14.gif Stop button to move it
  3. Open the cartridge cover.
  4. Press down all the ink cartridges until they click into place to make sure they are properly seated.
  5. Close the cartridge cover and push it down until it clicks into place.
  6. Close the scanner.
  7. Press the cp_button_14.gif Stop button to begin charging the ink. This takes about 2 minutes.
    When the On light stops flashing and remains on, ink charging is finished.
    Caution:
    Never turn off the Epson Stylus CX while ink is charging or you'll waste ink.
    If the ink light flashes, press the cp_button_14.gif Stop button and press down all the cartridges securely.
    If you remove an ink cartridge for later use, protect the ink supply area from dirt and dust and store it in the same environment as the Epson Stylus CX with the label facing upward. Note that there is a valve in the ink supply port, making covers or plugs unnecessary, but care is needed to prevent the ink from staining items that the cartridge touches. Do not touch the ink cartridge ink supply port or surrounding area, and do not store the cartridge upside down.
    If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Mar 22, 2011 | Epson Stylus cx7450 All-In-One InkJet...
My epson stylus cx6000 printer keeps showing -(install the ink cartridges) and I have already put in new ones. The code is E-02.
f you have just installed a new cartridge and you still see an ink related error message, the cartridge may be incorrectly installed. Follow these steps to make sure the cartridges are correctly installed:
  1. Make sure the Stylus CX is turned on.
  2. Check the photo viewer screen to determine which cartridge is incorrectly installed. Then do one of the following:
    • If printer shows the ink cartridge is expended, press the cp_button_6.gif Start button.
    • If the printer shows the cartridge is low on ink, press the Setup/Utilities button. Press the cp_button_41_er.gif or cp_button_42_er.gif button to select Press Start to change cartridges. Then press the cp_button_6.gif Start button.
  3. Press the cp_button_6.gif Start button again.
  4. Lift up the scanner, then open the cartridge cover.
alert_caution.gif Caution:
Never attempt to open the cartridge cover when the print head is moving. Wait until the cartridges have moved to the replacement position.
  • Press down all the ink cartridges until they click into place to make sure they are properly seated.
  • alert_note.gif Note:
  • Close the ink cartridge cover and press it until it clicks into place.
  • Close the scanner.
  • Press the cp_button_6.gif Start button. The Stylus CX charges ink for about one minute and displays Charging Ink on the photo viewer screen until charging is finished.
  • alert_caution.gif Caution:
    Never turn off the Stylus CX while the Charging Ink message is displayed or you'll waste ink.
  • Press the Setup/Utilities button to return to the previous mode, if necessary.
  • Aug 26, 2009 | Epson Stylus CX6000 All-In-One InkJet...
    E-90 error message on Epson CX6000
    If the error code E-90 appears on your Stylus CX control panel display, the print head may not be able to move back and forth freely.
    If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
    1. Turn off the Stylus CX.
    2. Lift up the scanner.
    3. Press down on the ink cartridge cover to make sure it is completely closed.
    4. Close the scanner and turn the Stylus CX back on.
    Also
    If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
    2. Lift up the scanner to access the printer area.
    3. Remove the tape from the ink cartridge holder.
    5. Close the scanner.
    6. Turn the Stylus CX back on.
    Aug 07, 2009 | Epson Stylus CX6000 All-In-One InkJet...
    Epson c20ux -ink cartridges installation
    Power on
    Open door or front top of cover that covers cartridges.
    Systen should move ink carrage to center so you can take out old and put in new.
    Close door/cover and should get some data on Monitor to follow so system recognizes new cartridges.
    If no work u have some type of a problem in printer.
    I'm assuming you don't have a paper jam or anything. If you do must clear.
    Luck
    JC
    Jan 18, 2009 | Epson Stylus C20UX InkJet Printer
    I am trying to put new ink cartridges ito the epson stylus ns400 series epson ink jet printer. how do I do that?
    Hold the ink button down for 3 seconds, the carriage unit will move out to allow you to change the cartridge
    Gremlin11
    Dec 13, 2008 | Epson Stylus NX400 InkJet Printer
    Changing the ink cartridge in Epson Stylus CX4200
    1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
    2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
    3. Press and release the INK button. The print heads will move to the left, and the cartridge that needs to be replaced will stop directly beneath the OUT OF INK symbol. Make a note of which cartridge requires replacement.
    4. Press and release the INK button again. If more than one ink cartridge is empty, the next cartridge will move under the OUT OF INK symbol. If no other cartridges are out of ink, the print heads will now move to the REPLACEMENT POSITION.
    5. Open the CARTRIDGE COVER. Pinch the front and back tabs of the empty cartridge as you lift it out of the unit. Dispose of this cartridge.
    6. Before you remove the new cartridge from its package, shake it four or five times.
    7. Remove the new cartridge from its package, and lower it into the cartridge holder. Push down gently until the cartridge clicks into place.
    8. Repeat steps 5-7 for each cartridge that you need to replace. Close the CARTRIDGE COVER once all of the necessary ink cartridges are replaced.
    9. Carefully lower the scanner, until it clicks into place
    10. Press and release the INK button.
    The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
    Caution: Never turn off the EPSON Stylus printer while the ON light is flashing, unless the Stylus printer hasn't moved or made noise for more than 5 minutes.
    May 15, 2008 | Epson Stylus CX4200 All-In-One InkJet...
    Epson stylus cx4200 all-in-one?
    1. Make sure the printer is turned on.
    2. Make sure the document cover is closed, then closed, then open the scanner.
    (Do not open the scanner when the document cover is open).
    3. Press and release the ink button. The 'On' and 'Ink' lights flash.
    If one of the cartridges is low or empty the printer moves that cartridge to the 'ink out' mark. Go to step 4.
    If no cartridges are low or empty the ink cartridge holder moves to the ink replacement position. Go to step 5.
    4. Pree the 'ink' button again.
    If more than one cartridge is empty or low the next cartridge moves to the 'ink out' mark.
    Once the printer identifies all the empty or low ink cartridges the print head moves to the ink cartridge replacement position.
    5. Open the cartridge cover, squeeze the tab at the back of the empty cartridge and lift it out.
    6. Before you open the new cartridge package shake it four or five times and remove it from the package .
    (Don't remove or tear the label on the cartridge otherwise ink will leak out) .
    (Don't touch the green chip on the front of the ink cartridge - you could damage the cartridge).
    7. Place the new ink cartridge into the cartridge holder and push it down till it clicks into place.
    8. Replace any other cartridges that need replacing.
    9. Close the ink cartridge cover and press it until it clicks into place.
    10. Close the scanner.
    11. Press the 'ink' button. The printer starts charging ink and the 'on' light starts flashing . This takes about a minute . When it's finished the 'on' light stops flashing and remains on and the 'ink' light goes out.
    You'll see all the above, with helpful pictures, at
    this Epson support page
    Mar 19, 2008 | Epson Stylus CX4200 All-In-One InkJet...
    Epson stylus cx5400 reset???
    try doing this :
    Reclamping the Ink Cartridges
    Once you start the ink cartridge reclamp procedure, you must complete all the steps in one session.
    1. Make sure the EPSON Stylus CX5400 is turned on and not printing.
    2. Press a MENU button until you see CHANGE CARTRIDGE, then press the COLOR COPY BUTTON. The ink cartridges will move to the replacement position.
    3. Lift up the unit's cover, to access the ink cartridges.
    4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
    5. Lower the cartridge back into its holder, then press down on the top of the cartridge until it clicks in place.
    Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
    6. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
    The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady.
    Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX5400 hasn't moved or made noise for more than 5 minutes.
    if the issue still persists - you need to call the vendor - it´s a hardware issue
    Dec 30, 2007 | Epson Stylus CX5400 All-In-One InkJet...
    22 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
