Question about Acer Aspire 5610-4648 Notebook
Changing backlight Does anyone have work instructions on how to change the backlight on a ACER 5610 laptop or is this something that needs to be taken in?
  • 1,512 Answers
Hi Ritterpusch
If yiou are technically minded, and take care, you should be able to do it yourself. The screen will need to be disassembled. You are best to get this tool BUT FIRST It is quite likely that the invertor that provides power to the screen may have failed. You can get a new invertor from here. Get both tool and invertor, try that first :) You use the tool to slide around the edges of the bezel that surrounds the screen. It then just simply clips apart. Good Luck
regards
robotek
Posted on May 06, 2008
  • Graeme Ross
    Graeme Ross May 06, 2008
    oh, and if you are a guitarist, I have used a thin guitar pic to do the same task. just slip it under the edge, and slid along...
My screen keeps going dark. I have replaced the
Its not the inverter, it's your backlight. Hard work to change, sorry, and it might be cheaper/quicker to replace the whole lcd panel at $100 (£65)
Jul 26, 2010 | Acer Aspire 5610-2328 Notebook
Acer Aspire 5610 LCD backlight problem
my laptop is acer extensa 4620 problem is web cam is not working what will do
Nov 05, 2009 | Acer Aspire 5610-4648 Notebook
If it is less than 1 year old, go to http://www.acerwarranty.co.uk for UK or http://support.acer.com/ for US.
I did this last year for my girlfriends laptop backlight problem and it was a free courier both ways and was repaired within 2 weeks (new part required). No cost to you.
Otherwise, sorry I dont know how to fix it.
Nov 05, 2009 | Acer Aspire 3680 Laptop
Acer 5515 backlight not working also bootmanager missing
You need to fix the boot manager problem first by connecting an external monitor to the laptop so you can see and do a system repair.
As for the backlight problem :-
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info
Aug 14, 2009 | Acer Aspire 5610-4648 Notebook
Screen getting darker
your case is the back lights inverter or lamp damage, you have to send to repair, find a laptop hardware specialist to do that, my repair cost (lowest)
1) repair the inverter board if repairable, $50
2) change the new inverter board $80
3) change the lamp $60
Feb 02, 2009 | Acer Aspire 5610-4648 Notebook
No Backlight when powered up Acer 5610.
Mine does this too. It is the inverter. Of course it goes wrong as soon as your warranty expires. It can result from Best Buy sending you the incorrect battery and them insisting to put it in even though the voltage doesn't match...
You need to replace the inverter. This page should help:
http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Jan 13, 2009 | Acer Aspire 5610-4648 Notebook
Replacing LCD inverter board on 5610
The better way is to get a service manual to be sure of follow the correct step to diss/asembly and not damage your laptop. You can get one from here, but you have to register to get access to the manual (about 5 eu).
http://www.nodevice.com/manual/newmans/acer/SG_AS5610_TM4200_BOOKpdf/get48623.html
Oct 26, 2008 | Acer Aspire 5610 Notebook
The backlight on my laptop is not staying on
There is settings for your screen in the display options. Sounds like you need to fix a couple settings.
Oct 17, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5610-4648 Notebook Logo
111 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
