Question about Xerox Workcentre 5225 / Copier, With 100-sheet Bypass Tray, 2 X 500-sheet Paper Tray, 2 X 500 Tray... Printer
FAULT CODE 124-373 ON WORKCENTER 5225 WILL NOT CLEAR
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
Posted on Jul 13, 2011
  • 2,335 Answers
Please review the fault code '124-373'.
The System Administrator Guide for the Xerox Workcenter 5225 lists 38 pages of fault codes but '124-373' is not among them.
I suggest you print (or display at least) the Error History Report, which will itemize and date all errors and faults. To do this:
  1. Press the Machine Status button of the control panel.
  2. Select the Faults tab.
  3. Select Error History Report.
  4. Press Start on the control panel.
I hope that helps.
Posted on Aug 28, 2010
    Problem Solver:
  • 6 Answers
Open left door after removing drum unit the machine will give you an error code 124-315
go to diagnostic screen ( 0+start ) and put the machine serial number
Posted on Aug 28, 2015
HI, I fix the problems as i just continue press the stop button and the power up the machine and the the error is dispapeared . My this will help u.
Posted on Dec 29, 2011
Dear All can any one tell me solution for this Error please XEROX 7228 Workcenter code 004-346 waiting for your kind replays
04.346, 04-562 Transfer Belt Home
The IBT Home Sensor does not detect the Belt Home signal.
If this fault is declared 3 times in succession, print mode will be disabled. In order to
clear this condition, reset NVM location IOT/Finisher 1221 to 0 in dC131.
Sep 15, 2015 | Xerox Office Equipment & Supplies
Code error 061-315 copy not coming
change the laser and it will be done. please don trouble your self just do as i am saying.
. remove the cover were the paper falls when you are making copies and take off the front cover until you reach the laser unit and replace with a functioning one. if you want some more help contac me on my cell number 00258 846427869
Apr 27, 2015 | Xerox Workcentre 5225 / Copier, With...
Our xerox workcenter 7235 fault code 024-360 and copy service is disabled
024 360 An error has been detected by the Controller during communications with the Printer. User intervention is required to Power Off/Power On the machine, Field Service is required if the problem persists. Printing is disabled.
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WC7228_WC7235_WC7245&Xlang=en_IN&Xcntry=IND
You will have to either get this printer repaired or replace it.
Aug 05, 2010 | Xerox Office Equipment & Supplies
Xerox 5225 fault code 010-320
that is a fuser overheat code suggest you have a techintion repair or replace the fuser
Jan 04, 2010 | Xerox DocuColor 3535 Copier
Error mesage
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly
IF these steps do not work you will have to replace the fuser or fuser heat rod then perform the reset.
May 15, 2008 | Xerox WorkCentre Pro 16fx Laser Printer
Xerox Workcentre 5225 / Copier, With 100-sheet Bypass Tray, 2 X 500-sheet Paper Tray, 2 X 500 Tray... Printer Logo
4,659 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
