Question about Acer AL2017 20" LCD Monitor
No Signal message displaying after screen goes black
I just recently bought a LCD Monitor a couple of days ago and until just recently a problem came up.
Once and while the screen will flicker black for about two seconds (usually about twice in a row) before returning to normal again and then stop. It didn't do this often. Then just today the screen went black and displayed the No Signal message while my computer was still running. So I did the whole reboot thing and stuff and it seemed fine once everything loaded until it displayed it again. It kept doing that for a while but its stopped at least for the moment. I know it can't be the power because I've checked the pluggs twice to see if they might be loose but they're tight in there.
What could be the problem?
  • Seira
    Seira May 17, 2008
    Thanks but what should I do if it does say Plug and Play monitor?
I have the same problem. Its really great to see that this is a known issue. I tried the solution of viziks, allthough my monitor still has the name ''plug and play monitor'' . I wanted to try to install new drivers, where can i find those?
Posted on Jun 11, 2008
    Champion:
  • 220 Answers
Try loading drivers for the LCD monitor.Right click empty part of desktop>>Properties>> settings It should show monitor name instead of plug and play monitor on ---- Video board.Go to Advanced>monitor>driver on this screen.
Samir
Posted on May 12, 2008
My Monitor keeps going black
Sounds like you have something overheating in the screen pull the back cover and blow it out.
Jan 20, 2013 | HP 17 1740 DVI Rotating LCD Monitor w/USB...
E228WFP display disappears Posted by
disconnect all the cable from the monitor except the power cable .
see if you see any test screen and keep it on ,if the test screen blacks out you monitor is bad ,better buy a new one as usually repairs cud be expensive
Apr 17, 2010 | Dell E228WFP LCD Monitor
Monitor starts then goes off, no signal
I would check the LCD against another monitor. It does not have to be a LCD, a regular monitor will do.
This will tell you 2 things, 1. The Video card is good or bad, 2. The Cable is sendinf a good signal.
If when you startup the monitor, you see a display and then after a few seconds it display's a no signal message, this is consistant with a Bad cable or cable ends. or Bad VGA card from computer.
Hope this helps. Good luck..
P.S. If you have move the PC, you may want to open the unit, and re-seat the Card. If the card is not making a solid connect on the board, it will display these syptoms.
Sep 05, 2009 | HP w1907 LCD Monitor
ViewSonic LCD Monitor Went Blank
It is probably a bad INVERTER and / or backlight fluorescent bulb.
Jul 02, 2009 | ViewSonic Computers & Internet
L1932TQ monitor flashes on, then blacks out
I would try connecting it to another computer or Laptop if you can to see if the problem is the same. You might also try disconnecting it from you computer and turning it on, it should “banner”(show a logo and or a no signal message). If it behaves the same way just a quick flash…. Sounds like its toast.
Jun 20, 2009 | LG L1932TQ LCD Monitor
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Black screen, blinking power light, no signal
Hi...there,
It's seems you got a defective DVI card. Try using a VGA cable instead. Have nice day!
Aug 22, 2008 | ViewSonic VX924 19" LCD Monitor
Samsung SyncMaster 17" LCD Blacks out
If you have a second monitor, you could use your computer until the monitor goes black... then plug in a replacement monitor. My guess is that one will display black too...
My gut feeling is that your VGA card is on the fritz... I'm not convinced it's your monitor. Do you have a replacement VGA card you can try? I'll bet that'll take care of the problem.
Apr 22, 2008 | Samsung SyncMaster 17" LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Acer AL2017 20" LCD Monitor Logo
502 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
