Question about D-Link DIR-615 Wireless Router
How do I reinstall a dlink 615 modem. mcafee syys a trojan has been identified each time I try the install disc. can I install without the disc and how?
  • 2,335 Answers
I can help you with your DLink DIR-615 router problem.
You don't really need to run anything from the disc to install a router - there is no setup program on the dlink cd you are required to run. Routers operate independently of the computers they are plugged into.
The most useful thing on that disc is the user manual, which you can download direct from DLink here. Any other bits and pieces that are on the 'installation CD' are also available from their webpage.
I hope that helps.
Posted on Aug 28, 2010
  • Paul Sager
    Paul Sager Aug 28, 2010
    Whoops, that link didn't make it.
    'which you can download direct from DLink here. '
    Here is that link:http://www.dlink.com/products/?tab=3
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
My Netgear router has just been replaced by Virgin Media with a DLink 615. The installation disc won't work, so can a connect without it? I'm running on XP and using Firefox as my browser cheers
You will need to reset the router to factory defaults before you can connect to Virgin Moble there should be a reset button on the back of the router press and hold for 30sec. and then reboot it
here is a link to help you setup the router
http://support.dlink.com/emulators/wbr2310/
If you futher assitance lt me know
Aug 31, 2011 | D-Link DIR-615 Wireless Router
I have followed instructions (several times) to connect my dlink router dir-615 and once I unplug the ethernet cable and attach to dlink (blue slot 1) and plug in power to the router....it no longer can...
the blue socket should be connected to your modem, it is this modem that supplies the internet for your router to distribute to your computers so if you disconnect the blue cable from your router you are disconnecting the internet
Apr 17, 2011 | D-Link DIR-615 Wireless Router
Can i install my new dlink 615 without using the disk aS MY DRIVER IS BROKEN
Hi if your disk drive/cd drive is not working and you cant use the disk then all you need to do is go to google search and type in the following
type in either of these:
free firmware for dlink 615
or
free drivers for dlink 615
then hit search this will then list loads of sites that will let you download what you need for this device for free, now if you have to download them off another computer you need to download it onto a usb stick so as your computer can get the drivers put onto it.
if you can access the internet from your own computer then just download the drivers or firmware then it will install it for you, it might be worth typing in what os your using such as vista or windows 7 into the search as this will find the exact copy you need.
most sites will ask what operating system your using before it lets you download
have a go and you should find you will have no problems
let me know how you get on or if you need further assistance ok
Aug 03, 2010 | D-Link Computers & Internet
MY INSTALLATION DISC FOR DIR-615 ROUTER IS DAMAGED
you dont need a disk to set up the router - you can set it all up via your PC the user manual for the dir-615 http://www.dlink.com/products/?pid=565 if you click on "support resources" button then choose your country
direct link here to UK http://www.dlink.co.uk/cs/Satellite?c=TechSupport_C&childpagename=DLinkEurope-GB%2FDLTechProduct&cid=1197319391320&p=1197318962293&packedargs=locale%3D1195806691854&pagename=DLinkEurope-GB%2FDLWrapper
The chances are that the default settings may work with your MODEM - but if not then the settings are straight forward
post a comment back on anything you dont understand
Mar 21, 2010 | Computers & Internet
Trouble replacing a USB modem with a Dlink 615 on Virgin Media
First: Turn off your USB modem.
Second: Setup your D-Link for connection
Feb 25, 2010 | D-Link DIR-615 Wireless Router
Unable to connect my mac to d link worked ok until new modem was installed now will not connect mac computer sends a message you are not connected to the internet. have tried rebooting the...
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 29, 2010 | D-Link DIR-615 Wireless Router
Trying to hook up a dlink router using cricket broadband wireless modem. need help?!?!?
Cable-modem (or DSL-modem) --> WAN port on CRICKET
and you _have_ a wireless network, without using the D-Link.
If you really want to get yourself confused:
LAN port on Cricket <--- Ethernet "cross-over" cable ---> WAN port on D-Link router.
Jan 28, 2010 | D-Link DIR-615 Wireless Router
Dlink DIR-615 wireless connection problem
hi. with regards to your concern. there is a possibility that the wireless network adapter driver is corrupted.. try uninstalling the driver for your wireless adapter and reinstall again. once setup is done, view the available wireless connection and connect.. it will ask u the password if there is..then it will connect. if this solution dont work.. try to check your wireless settings, maybe there is a problem on the settings..
Aug 07, 2009 | D-Link DIR-615 Wireless Router
D-Link DIR-615 Wireless Router Logo
259 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
