posted by tootncoot on May 06, 2008
Where do I put in the water. What buttons do I push to release water and to **** up the water. I bought a cleaner without any directions.
Solution #1
posted on May 15, 2008
The upper tank is the solutiontank. You mix you water and cleaned in it. The when you pull back slowly squeeze the trigger to release the solution and it will vacuum up also in the the lower recovery tank.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Hoover SteamVac Carpet/Upholstery
Email this problem
Email this problem
Can you Help with these Vacuums problems?
Hoover SteamVac Carpet/Upholstery Deep...
restrictive valve
restrictive valve
moments after starting the vac... Answer This...
when i fill the water
when i fill the water and soap... Answer This...
My carpet cleaner will not
My carpet cleaner will not pick... Answer This...
cant get upholstery part on
I know where part goes but... Answer This...
Hoover Steamvac Model F6020-900...
The upholstry attachment outer... Answer This...
Repair Service
Find Vacuum Repairman Near You:
