Question about Dryers
Know when i turn the dryer it has a high pitch sound what cold that be and can i fix that myself..... help please!!!1
  • 2 more comments
  • Anonymous Aug 05, 2008
    has loud squeaking noise for a while then quits also looking for repair manual and diagram Thanks
  • mamadoog Aug 05, 2008
    I have SDE4606AYW model Maytag. Squeals real bad at beginning then quits. Also looking for diagram and manual for dryer.
  • mamadoog Oct 08, 2008
    Maytag SDE4606A squeaks need to know how to replace belt
  • eric bosman
    eric bosman May 11, 2010
    make and model number pls
    Genius:
  • 1,073 Answers
What is the model number of the dryer
Posted on May 07, 2008
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
Dryer was making high pitched squealing noise and now won't run
Please supply the model number so we can help further.
May 20, 2012 | Hotpoint Dryers
We have 98702. the dryer makes a loud rubbing, or knocking noise. at first listen, it sounds as if there were metal in the dryer rattling around. this is a steady noise. i am interested in fixing myself....
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 25, 2011 | Kenmore 98702 Stacked Washer/Dryer
I have a Kenmore 80 Series Dryer around 13 years old. Dryer works fine with one exception. It is making a high pitch squeaking, screeching sound. It does seem to be as prevalent when it is empty, however,...
if the model number starts with 417. instead of 110. it has a rear bearing in it that needs to be replaced.i need the model number to help you.open the door and look around the opening and you'll see a tag with the number.
Feb 02, 2011 | Dryers
I have a kenmore gas dryer model 70722990 when you turn it on it has a very high pitch squeal sound runs for 5 minutes then turns it's self off and won't turn back on. can you please tell me whats going...
heatman101
Asker
Dec 27, 2010 | Kenmore Dryers
High pitch squeeking when turn on dryer after 20 minutes sound goes away... i want to fix myself how to i get to broken part
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 20, 2010 | Washing Machines
MATAG DRYER, MAKES A VERY LARGE HIGH PITCH SQUEEL
heatman101
Apr 15, 2010 | Maytag Dryers
Dryer making a high pitch squeeling sound when
The idler bearing that keeps tension on the belt is going out due to heat leaching the grease out of it. Have it replaced.
Apr 13, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Screaming acer!
sometimes if the inverter board (the part that drives the backlight) has a cold solder joint on it, it can actually generate a high pitched resonating sound (aka a screaming squeal sound)
if it's under warranty, have the manufacturer correct the problem.
if not under warranty, retouch the solder points on the inverter board, or have a repair tech fix it for you.
Jun 03, 2008 | Acer AL1916W 19" LCD Monitor
Squeeky noise
I own a Frigidaire Heavy Duty Dryer The Model # is FDE436RES1. It is 10 years old. When running the dryer it makes a very loud squealing noise although the heat and the dryer still work. Is this a belt or roller problem or does it sound like something else. It is very high pitched and can be heard throughout the entire home. I do not know much about dryer troubleshooting so your help would be greatly appreciated. Thank You.
Oct 17, 2007 | Frigidaire GLER642A Electric Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
