Question about Woods 201 cu. ft. Upright Freezer V2003RW3
How do i deforst it - Woods 201 cu. ft. Upright Freezer V2003RW3
  • 15,935 Answers
Empty then unplug for 24 hours or so.
To speed it p a tad - you could use a hair dryer directly on the evaporator coul.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Aug 28, 2010
I HAVE LG GR-T252GP 250L HAVING DEFORSTING PROBLEM
Empty appliance until fully defrosted.Turn back on IF this happens again first replace the thermostat if this does not work the appliance may need new as or new compressor
Aug 15, 2012 | Freezers
Glrs237zdw temp goes from 29 to 60
I am not sure if you said you checked the=> 5303918476 Defrost Control Board or here=> 5303918476 If you replaced the defrost thermostat inside the freezer that is most likely not the problem. These defrost control boards will really cause strange things to happen. Sometimes by unplugging and taking out the control board you will see burn marks or signs of heat damage on the printed circuit, not always. Unplug and open the control panel inside the fresh food compartment=> GLRS237ZW2 Control Panel
You will see part/location number 23 is your 5303918476 Defrost Control Board If I misunderstand please let me know so I can help you resolve this problem. Thanks Sea Breeze
Feb 12, 2012 | Frigidaire Freezers
Hai this is arun from oman.. i want to know how to
Check the defrost timer is operating and that the defrost heat element is working, usual cause of ice build up in most units, you may want to get an electrician to do it coz one wrong move it WILL kill you. Good luck.
Dec 18, 2010 | Desmond 49 cu. ft. / 1388 liter Commercial...
FRS6HR5HSB6 model frigidaire side by side fan making noise. Ice is building up around fan. What is causing ice buildup
the defrost circuit has a problem, allowing the frost/ice buildup..
remove the shelves, and back lower cover in the rear of the freezer to expose the evaporator coil, defrost heater, and defrost thermostat.
the defost heater should have continuity through it and the defrost thermostat will have continuity when frozen but test open when warmed.. if either bad replace.
if both test good look for bad connections in the freezer compartment wiring, and moly connectors otherwise the temperature controls are bad and it is an electronic assembly that incorporates the temperature controls with the deforst timer controls..
hope this helps,
best of luck,
ttfn
Nov 03, 2009 | Frigidaire Freezers
Kenmore freezer deforsted suddenly. Comes on
compressor relay is probably going out...also check the plug in to the wall. A intermittant contact is a matter of following the source to the compressor. start at the plug and through the temp sensor/ t-stat defrost control and down to the compressor. but ususlly the compressor relay is the culprit.
Oct 25, 2009 | Freezers
Lost vacumn, door popped open alarm on
If is the type of freezer where the shelves are also the evaporator(shelves are very cold and is normal to frost), the fact that only one shelf is iced would indicate the system is low on freon due to a leak. This would also explain the hot walls and compressor. It requires a service man to check the freon level and locate leak and recharge.
Sep 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I have a maytag freezer does it self defrost?
If it has a fan in it, it's self defrosting. The moving air burns away the frost and 8 out of every 24 hours, the defrost timer will turn a heating element in the cooling coils, to melt away any ice buildup.
If it isn't a self defrost model, you can safely defrost it woth a pan of hot water. I also use a spray bottle woth hot water to help the process. DON'T use anything electrical to make the heat. Water can drip into or onto it and you could get electrocuted.
Sep 03, 2009 | Maytag Freezers
Deforst mechanism
you need to have a defrost or the freezer will not work unplugging the time clock then the compressor will not work. Tom
Jun 18, 2009 | Freezers
Not cold enough. ice on back of freezer but not making cubes
sounds like you might have a deforst problem or your drain is blocked not allowing the water to drain when the fridge goes into defrost.
Apr 24, 2009 | Freezers
Woods 201 cu. ft. Upright Freezer V2003RW3 Logo
27 people viewed this question
Top Woods Freezers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Woods Freezer Expert? Answer questions, earn points and help others
