Question about KitchenAid Dishwashers
Dishes are not clean when I unload them - KitchenAid Dishwashers
  • KitchenAid Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 28, 2010
Clean light blinking
If the clean light blinks four times and then pauses and then blinks four times again and repeats, the problem is your pump motor. If there is water under the DW the pump clamp has probably failed and sprayed water onto and inside the motor. Call a certified Kitchen Aid repair service.
Aug 13, 2014 | KitchenAid Dishwashers
I have atlas copco compressor whose main motor rated current is 128 amps but it draws 144 amps, checked for bearing and winding its absolutely OK...please suggest
see this sometimes when rentals come back in , seems some enterprising individual went in a adjusted the unloading point ,to get more air from machine (thinking) to a higher point , what this does is now not allowing air to unload from dish point , so useing P=AsQ this builds up air inside machine makes motor run more amps to do it too , so this is where id start to look , watch your unloader work , especally if dish valve is slow throttled back closed , if it fails to move you have a fault in your unloader , can be many reasons , from someone meddling like i described or a componet failure
Mar 04, 2014 | Air Tools & Compressors
I have a Whirlpool Gold Quiet Partner III dishwasher. When I unload the "clean" dishes, there is some type of film or crud on the dishes. I have to hand wash them to get this off. It seems like a...
You need to check the drain system completely, look for plugged screens, pump impellers, valves and the drain hose. You need to witness a large volume of water flow during drain.
Sep 19, 2010 | Whirlpool Dishwashers
Dishes seem to have a powery residue on them after they're clean
Check inlet water quality for hardness. If salt chamber is provided, fill the chamber with salt meant for washing machine.
Use the recommended wash soap.
Check rinse aid and fill if required.
Jul 20, 2010 | GE 24 in. GLD5560LSS Stainless Steel...
When the cycle has finished and I open the door to unload the dishes the dishes ar edry but the is water running down the inside.
The solenoid valve connected to your inlet requires cleaning. If you can access it it take it out and clean the vents. Switch off power. Note down the connections before you disconnect the leads. Mostly it is push in/ out terminals.
May 21, 2010 | Dishwashers
Dishwasher won't run
yes the water going to the machine and the water valve has to be ohmed out with a meter
Feb 28, 2010 | Bosch SHE4AM12UC Dishwasher
The green clean light keeps flashing even after unloading dishes and replace with dirty dishes. now i can't get the dish washer to start washing
This may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Sep 23, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
My dishwasher washed my load of dishes, but did not drain. So I unloaded it, and then hit the drain button. It wouldn't drain. If I hit any of the other buttons to rinse or wash the dishes it works, but it...
There is a drain hose for your dishwasher that often gets clogged. Remove the drain hose and clean it out. reinstall the hose and your dishwasher will drain. The dishwasher should have a panel to remove and then comes out easily, just be careful not to pull it out too far. If this does not fixya then you may need to throw some parts at it, but hopefully not. Good luck
Jul 12, 2009 | Whirlpool Dishwashers
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
Not cleaning at all - most dishes end up being washed by hand afterwards
Hi there!
You've done the basics, so we'll treat it as a fault due to wear.
When running, do you hear the spray arms rotating - about twice a second?
If the water is actually reaching the dishes, bur the arms are not rotating, you may need replacement spray arms.
If the water is not even reaching the dishes with any force, The circulation pump may be faulty and needs replacement.
Hope this helps you.
Jun 17, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishwashers Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
