Question about Nintendo NES Console
Hi, My nes only displays a white screen when switched on with a game inserted. I have changed the 72 pin connector to one which I know works, cleaned the contact points the connector slides onto and used a game with clean contacts, which I know works. Still only a white screen. My thoughts are there must be a fault within the circuit, but which components should I look at (I have a dead system which does not power up I could canniblise parts from)? Again here I have checked to see if any components have poor solder joints and cannot see any problems. Can you help?
    Problem Solver:
  • 19 Answers
These symptoms are a pretty good indicator that it probably is your 72 pin connector that is grimy, pitted or too lose. The first option is to get a 72 pin connector cleaner. It's built like a NES game you put in and pull out to clean the pins. That works if the pins are not pitted or loose. You can pick one up for about 8 bucks or less. The second and (IMHO) best option is to replace your 74 pin connector. It's not that difficult, and can be accomplished with a Phillips screwdriver in about 10 -15 minutes. nesrepairshop.com supplies directions with the ones they sell and it's not hard. The pin connectors run about 10 bucks. I would go with replacing the connector or sending it in to a shop and have them do it for you if you don't want to attempt it.
Posted on Mar 27, 2015
Hi, probably need a new 72 pin connector, or you have bad capacitors or broken traces. we fix all those, check it out www.consolesolutions.net/nes
Posted on Sep 01, 2010
I have 2 Nintendo NES systems. One I thought didn't work and needed the 72 pin piece changed, but when I turned it on the other day, it sort of worked. The people in the games came up with letters and...
Secret trick: take NES cartridge, press cartridge down and waggle the cartridge inside the NES and then hold the NES down and shove the cartridge onto the pins. An alternate solution is to take a Q tip, dip it in rubbing alcohol and clean out all the dust inside your game.
Mar 23, 2015 | Nintendo NES Console
Nes displays solid blue screen after i installed new 72 pin connector
Try cleaning the game packs out with qutips and rubbing alcohol too and the game port is dirty too try cleaning the game port out with compressed air cans.
Jul 23, 2012 | Nintendo NES Console
The red light flashes on my NES and on the TV screen, it keeps on changing colors. Do you know whats wrong?
The NES is touchy like that, sadly-- your problem isn't uncommon. My NES, and the NES of nearly every friend I have who still owns one, plays this little trick on them from time to time. Here's what we do:
1. Turn off the NES console.
2. Blow into bottom of the game, near the chip that connects to the NES.
3. Wipe away any excess dust from the game itself.
4. Blow into the console of the NES.
5. Wipe away any excess dust.
6. Re-insert the game and try again.
If this doesn't work, try placing the game in more delicately, or with more force. It's just a matter of trial and error, and sometimes it will work faster than others. Hope this helped!
Mar 12, 2011 | Nintendo NES Console
I have changed the pin connector on my nes, it does not flash anymore but now i get a blank screen can someone help me?
First try connecting through the av ports on the side of the console rather than the RF port on the rear of the unit.
If that doesn't work then your problem is likely a loose connection inside, go back in and reassemble.
I have had this issue with several consoles; these two solutions usually take care of it, though in rare cases a defective 72 pin connector was at fault even though it was brand new.
Good luck.
Mar 31, 2010 | Nintendo NES Console
Nes power light oes on and off
The nes does this to stop people from playing pirated games, but it can also be because the game cartridge or console is dirty. Try cleaning inside the game cartridge with a cotton bud dipped in a cleaning product of some kind. it mostly works for me!
Jul 09, 2009 | Nintendo NES Console
NES console - white or green tv screen
first off flip your nes upside down and remove the screws to the cover of nes..... then flip your nintendo over and remove the cover.... remember you just voided your warranty for your nes..... then proceed to do the following:
find Chip 3193A and find the 4th pin on the left hand side near the blue coils. Remove or pull back the pin and your NES Will play Pal and NTCS games.
Sep 17, 2008 | Nintendo NES Console
White dotted lines on screen of NES
Clean your games too once you replace the 72 pin connector or you're just dirtying it up again. Not to mention the games has enough crud to keep them from working correctly.
Mar 28, 2008 | Nintendo NES Console
Nintendo NES Repair
It's as simple as unscrewing the console by removing all the screws from the bottom. Once inside take off the metal piece over the area where the game is inserted. Once under there you can remove the two screws that hold the 72 pin connector in and pull it out and slip a new one in. Put it back together in reverse.
Mar 26, 2008 | Nintendo NES Console
Nintendo NES Console Logo
339 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
