Question about Kohler Electrical Supplies
I have a kohler cv14s engine is will not start it backfire
  • abraham581 Aug 28, 2010
    i have a cv14s will not start just backfire
  • 10,319 Answers
Readjust the valves to eliminate the backfire so it will start
Posted on Aug 28, 2010
  • 10,865 Answers
Hello. If you are pressing the start button and the generator is turning over, but won't start, it could mean several things. First, your fuel pump could be bad. Second, Ingnition coil is bad. Third, faulty spark plugs, or carberator is gunked up. Also, check compression. Should be over 110 psi. If you want to try a couple of things yourself do these things:
1. Check to be sure the air filter is clean.
2. Check to be sure that the fuel filter is clean.
3. Get some starting fluid and give it a couple of squirts then start it. If it starts up keep spraying starter fluid to keep it running for a minute or so to clear out the carb. After that it may keep running on it's own. J.
Kohler command cv14s rolls over but backfires through carb
Check the resistance (ohms) of your new switch and wiring. Sounds a though you are not getting good voltage, also check battery voltage.
Sep 17, 2015 | Garden
Why does my Vintage Cub Cadet 125, Kohler 12HP engine pop/backfire and die when given any throttle?
Carburetor needs adjusted. May need rebuilt or just cleaned. Could be one of the jets is plugged.
Jul 19, 2014 | Cub Cadet Garden
What would be the cause of a Kohler 25hp twin, backfiring through carb from one cylinder
Bad plug, ignition wire, valve clearance, or valve damage, vacuum leak at manifold. Timing cam off / damaged
Jun 16, 2014 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Hi I have a craftsman mower I am working on with a cv14s kohler engine. The engine will not start and just backfires through both the carv and the muffler but mostly the carb. I have removed the head and...
I am not sure, but years ago, the key that locks the "flywheel" to the engine shaft broke. That allowed the flywheel to shift on the shaft with respect to the piston movement, thus producing terrible timing. See if that is your problem and please let me know either way. This problem comes up alot on FixYa and I don't like guessing too often.
Gary
Aug 20, 2011 | Craftsman Garden
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Oct 10, 2010 | Craftsman Garden
Owners manual for a toro cv14s
go here https://lookup3.toro.com/request/request.cfm they have a link where you can print your own owners manual for free....good luck
Apr 05, 2010 | Toro Lawn Mower With Toro Power Tools
Electrical Supplies Logo
530 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
