SOURCE: PS3 Internet Connection/Upgrade System/Online Play
Do an internet connection test. Your NAT type should be either 1 or 2. If not then there are some restricted ports on your router.
I find that putting your PS3 in your router's DMZ (demilitarized zone), solves all connection problems.
SOURCE: keep gettin error code 80710723 when updating system on ps3
mae your playstation 3 wired then download it. once downloaded then go back to wireless.
SOURCE: error code 80023017 on ps3
It means everything is down for maintenance. Wait a few hours and everything should be cleared up.
ps3 error 80028e02 can be caused by different source of networkblockages. If you happened to be in a filtered network, that's your most probable reason why your ps3 is unable to connect online. For example, if you're in a school campus, there's a high chance that the IT network administrator has placed some restrictions to prevent hackers and other malicious online activities. You can refer to the campus IT department to find out if you need to access their local page for some clearance in order for your ps3 to connect online.
If you have your own internet connection, the next probable cause is a router. Placing restrictions on some IP address or net services may have accidentally include your ps3 in it. You can change some settings within the router to grant your ps3 full access online, while at the same time maintaining other restrictions that are already in place.
Another possible remedy is have your pc internet connection shared, and use your ps3 to use that shared connection to go online. These solutions are sure fire methods of keeping ps3 80028e02 away from your console.
