Question about Hotpoint HTS16HBR Top Freezer Refrigerator
Hello. Our unit is still running but the fan(s) seem to have stopped. We are going to have it looked at but not for a couple of days. Will the food stay cold enough if the fan is not moving the cool air around? It might be 3 or 4 days.
  • Hotpoint Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
Freezer fan dead?
Could be the defrosting that is not working. The fan starts touching the ice build up on the back that then causes the noise. A few days later the fan will get stuck on the ice as it keeps on building up due to no defrosting taking place. Unit will keep running as the set temperature inside the cabinet cant be reached because the air distribution will get blocked of due to the ice build up and stuck fan.
Oct 06, 2017 | Northland 24" Built In Top Freezer...
Exterior CKL49-1A AC Unit not blowing cold air
Why you need to change evaporator coil when condenser fan not working ,also why would you even charge unit with looking for leak.
Maybe the evaporator coil is leaking and when you recharge it it work for couple of days now unit is empty again .
If unit have low pressure switch then outside unit would shut off.
Jan 05, 2018 | Coleman Heating & Cooling
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
Hello, My name Zoltan, and I have a Maytag
Your defrost element has failed in the freezer, ice has built up in the freezer cooling cores and air cant pass through them to the fridge, you need to defrost the unit totally and replace the elements, they are at the inside rear, behind the plate, also check your internal fan is running in the freezer, could be another fault. Russ
Jun 26, 2011 | Maytag Freezers
I recently replaced the fan motor and capacitor for my condensing unit. The fan worked fine for a couple of days, but now after the unit turns on and runs for a time (minutes to an hour or so) the fan...
Yes, you either got a bad capacitor or the wrong one. As, it seems that it's overheating. When that happens it shuts OFF. After an hour of cooling, it functions again. If that's the case, in no time at all, it will fail completely.
Hope this helped you. Please let me know. Thanks.
Jun 17, 2011 | Heating & Cooling
Hi. I recently installed 1.5 T, 3 * Split AC, LG. Whole day the AC works fine and no problem in cooling too. But once in 2 day outdoor unit start making thudding noise continously and does not stop for 4...
Hello
Sounds like the compressor is shuting down on high heat.There could be a couple reasons for this.
1 Check that proper voltage is being supplied to compressor.
2 Freon level may be low.This would be a service call.
3 Bad or intermitent connection at thermostat.
4 Main contacts to compressor sticking,usually burnt or pitted.
Apr 08, 2011 | LG Heating & Cooling
Whirlpool ER8AHKXRSO - STAINLESS STEEL
Usually when this happens it is because of a problem with the fan that moves cold air from the freezer section of your unit to the refrigerator section. Either the fan has gone bad or the unit has frosted up to the point of stopping the fan. Try defrosting (unplugging) the unit over night and then check it to see if the fan runs. If not then replace the fan. If it runs and then stops after awhile like days or even a few weeks, then you may need a defrost timer.
The other thing that can cause this is the heating element going bad, but this is not usually the problem. The element can be checked with an OHM meter. If the coil does not have any resistance then it is bad.
You can find parts for your unit by doing a search for “appliance parts”.
Once you get the results of the search, pick a site and when it comes up it will usually ask for the model number of your unit.
Enter your model number and you will then get a page with exploded views and a parts menu.
Find the part you need and then order it.
Check a few different sites to be sure that you are getting the best pricing.
Most sites can have the part to you in a couple of days.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 21, 2009 | Whirlpool ER8AHKXRS Stainless Steel Top...
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Hotpoint HTS16HBR Top Freezer Refrigerator Logo
27 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
