Question about Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity Gas Dryer - White
Electric samsung dryer is not drying what should i do
  • Samsung Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Aug 29, 2010
Samsung dryer. It starts, but it doesn't get hot?
Samsung Dryer Diagnostic Repair & Diagnostic - Not ...
? 19:33
https://www.youtube.com/watch?v=a-8UFyRXBDg
Feb 7, 2014 - Uploaded by ApplianceVideo.com
Troubleshoot your own Samsung Electric Dryer that has some of the ... It powers on but when I get start nothing happens... drum spins but not ...
How To Fix A Clothes Dryer That Is Not Heating Or Drying ...
removeandreplace.com/2013/.../fix-clothes-dryer-heating-drying-clothin...
Sep 21, 2013 - At times your dryer can overheat and this can cause the motor that turns the ... Clothes Dryer Will Not Stay On After Pushing Start Button My dryer will run if I ... I have tried the trouble shooting tips for a dryer that doesn't dry but to no avail. ..... I have a 3 year old electric Samsung dryer and it stopped heating.
[FIXED] Samsung dryer runs, no lint clogs, good airflow, but no ...
forum.partsdr.com > Forum > Appliance Repair Help > Dryer Repair
Mar 12, 2013 - 16 posts - ‎4 authors
I want to check the third harness it but it doesn't look to slide out too easy once I remove the one phillips screw. ... Dryer gets nice and hot now!
Jan 19, 2016 | Samsung Dryers
Samsung dryer over dries
Sounds like the thermostat sensing tube did not get placed back in it's original position.
Oct 01, 2014 | Samsung DV448AEW 7.4 Cu. Ft. Electric...
Samsung dryer isn't drying
The vent may be clogged. Also, rugs can take a long time to dry because they are so heavy.
Apr 12, 2014 | LG DLE5977 Electric Dryer
I have a DV337 Samsung dryer, under sensor dry, normal, the clothes still come out damp,(this is a light load of clothes), when I switch to heavy duty, very dry level, temp high, for 1 hr they almost dry....
Go visit the local appliance repair store... a small Mom and Pop's store are usually great to help you.. explain what's happening and they should be able to sell you a sensor kit, I have replaced mine twice in 16 years... no biggie if you are semi electrical and mechanically inclined...
(the kits I have to purchase come with an electrical dryer sensor and a gas dryer sensor)..make sure they show you which is which,,
Jun 19, 2017 | Samsung DV337 Electric Dryer
Samsung electric dryer model # DV328AEW not heating up to dry clothes
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101.,//';
Mar 09, 2011 | Samsung DV448AEE Electric Dryer
Dryer will not dry
There are a number of things that could cause your dryer not to dry...
Check out this tip that I wrote about that..
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Mar 28, 2010 | Samsung 7.3 Cu. Ft. Super Capacity...
This may be a problem with your moisture sensor or the control that read the sensor. If it is under warranty have Samsung fix it for free. Make sure the cycle settings are correct before tinkering. First make sure the electronics are not too dusty. You could blow them off or vacuum them. Dirt particles can conduct electricity and make it read wrong. Next check the electrical connection for the moisture sensor. See if its location is in the manual. If it doesn't work after some tinkering asked the service for the dryer about possibly replacing the sensor but first try hard to get it to work.
Jun 13, 2008 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity Gas Dryer - White Logo
235 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
