Question about Samsung CLX-2160N All-In-One Printer
Clx2160 invalid imaging unit, How do t get into the test service mode to reset the counter or error message. The imaging unit is not invalid.
  • 3 Answers
Try a factory reset by pressing menu->ID Copy->Left->Right->Menu->Black Start consecutively. p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 9.7px Helvetica}
Posted on Nov 23, 2010
  • CleanUpKid Mar 15, 2011
    Well Done, you have saved me so much time and money, Samsung wanted 90 quid plus vat just to do that!
I receive malfunction error code cof32
John,
Need to replace the developer and the drum. Ensure that the counters for the developer and drum are cleared first (in service mode) before pulling the image unit out (Right side of machine) then take the image unit a part replace the developer, cleaning blade and drum. DO NOT USE A VACUUM Cleaner to remove the developer, because static electricty from the Vacuum cleaner can destroy the sensor located below the image unit, which is what is giving you the code. but you should change the developer and drum first. After that you run the F 8 procedure in service mode. Ensure the FAX and printer cables are removed do not want a Print job or fax to come in before running the F 8 or you will start over with a new developer. If you think you can do all this GO for it, if not get a tech out to do it.
AND NO JUST RESETTING THE COUNTERS WILL NOT WORK!!!! The machine use the counters to determine the correct voltages to certain assemblies. If you reset the counters that tell the copier parts are new when in fact they are old and you get codes and image issues.
Apr 30, 2016 | Minolta DiALTA DI2510F All-In-One Laser...
I have a Konica Minolta bizhub C351 that has an error message " transfer roller unit needs to be replaced soon" I purchased and replaced the "image transfer roller unit 4049-411 that also has the nu
Enter in the service mode:
Press Utility key - Meter count - Details - Counter mode - select present parts life and reset(clear) the transfer roller counter.
Mar 25, 2013 | Konica Minolta bizhub Office Equipment &...
How to clear the error replace maintenance kit
In service mode:
SP7804
7804 1 Paper
7804 2 Transfer Roller
7804 3 Paper Feed Roller
7804 4 Fusing Unit
Take note:
SP5930 001 Meter Click Charge
[0: No] default
This setting is for machines where the operator is responsible for replacing the Maintenance Kit.
(PM counter resets automatically after the user replaces the fusing unit.)
[1: Yes]
This setting is for machines where the service technician has responsibility for servicing the machine.
The service technician must reset the PM counter after completing machine maintenance.
Mar 19, 2013 | Ricoh MAINTENANCE KIT TYPE 6330N...
I was getting a message that the transfer belt needed to be replaced and I replaced it. But the message won't go away.
try this:
1. Press # sign; then 1934
2. Press MENU
3. Arrow to Tech Mode (not User Mode); press OK
4. DataSetup; move arrow to Clear All Memory
5. Clear All Memory; press OK
6. Choose coonutry; press OK; will erase and print out configuration report; clearing the transfer belt error.
This wipes out the counter on the Transfer Belt. Clear All Memory means all your settings are wiped out. This also reset all the counters EXCEPT the imaging unit counter.
Trust this helps. Please vote.
Dec 14, 2010 | Samsung CLP 300 Laser Printer
I need to reset the transfer belt counter Samsung ClX -2160
enter tech mode by pressing menu>idcopy>left>right>menu>back>menu ,then in data setup clear all memory and clear count
Mar 09, 2010 | Samsung CLX2160 Multifunction Color Laser...
Our bizhub-250 receives a C2557, need help with service mode
Utility/Counter -> Details -> [STOP][0][0][STOP][0][1]
Go to counter and clear the life of the developer and drums and then run F8 from functions.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jan 11, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Canon mp730 Error message
Dear sir,
physically you can't replace that part ,its a EPROM counter, which shows you the error message .you can only reset the counter through that procedure.otherwise if you want to replace that part then you have to contact authorised Service centre , to replace that part.
Regards
Dec 17, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Imagerunner 330S
this is the webb code for your fuser unit you have wo things to do in service mode 1st claer webb count touch counter misc webb clear key in that order then in this order function clear err ok turn off then on main switch
Dec 01, 2008 | Office Equipment & Supplies
Resetting
Check and see if the fuse has blown on the unit.  If it has, the machine probably needs the firmware flashed.
Oct 03, 2007 | Office Equipment & Supplies
Alarm light on. F80
This worked for me on an F60 and someone else on an F30. Re: Check Printer error message on Canon MultiPass by watsonk (6/7/05 11:16 PM) reply + / - It could be due to "waste tank full" alarm; you may need to reset the waste tank counter. I found a reset sequence for a MP730 printer in this website that works for F30 as well. Try: Resetting the Waste Ink Volume Counter 1) Enter SERVICE MODE.--- By pressing Menu-Copy-# 2) Select TEST MODE. 3) Select [8] PRINTER TEST in TEST MODE. 4) Select 3. [EEPROM CLEAR]. 5) Select 0. [INK COUNT]. 6) Press the [OK] key. 7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key. Skip step (6) since there is no [OK] key on F30 printers.
Sep 29, 2007 | Canon MultiPASS F80 All-In-One InkJet...
Samsung CLX-2160N All-In-One Printer Logo
1,582 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
