Question about Garden
Can someone show me a diagram for the transmission drive belt for a 42in. murray model #42598x92 or tell me how it goes around the pulleys
lester482529
  • 226 Answers
SOURCE: drive belt diagram for mtd rideon
hi;go to partstree.com.put in your model # and make.then click on deck assembly.it will be what your looking for.hope this helps.please rate this;Thank's
Posted on Jul 04, 2009
mowerman1857
  • 389 Answers
SOURCE: Murray model # 425303x92 primary drive belt #
Go to www.murray.com/manuals/ , input yourr model number and download what you need
Posted on Sep 14, 2009
mowerman1857
  • 389 Answers
SOURCE: The mower deck drive belt slipped off the idler
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Posted on Sep 30, 2009
mickey813
  • 472 Answers
SOURCE: Belt replacement poulan 27045
NO IF YOU HAVE THE RIGHT BELT IT SHOULD GO ON
Posted on Oct 01, 2009
mickey813
  • 472 Answers
SOURCE: the deck belt on my ride on mower - murray
21a49d6.pngHOPE THIS HELPS YOU LET ME KNOW
Posted on Nov 19, 2009
Testimonial: "Thanks for the info. Really clear diagram and easy to follow which was great."
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
Belt drive diagram for a murray lawn mower model number 42598x92
Visit the Murray website at http://www.murray.com
They have downloadable manuals and diagrams there.
May 14, 2015 | Murray Garden
Spring mount location for belt tensioner for murray 45256x92a
Try this site to get your manual and see if the exploded parts diagrams help
Mar 30, 2015 | Murray Garden
I have a 1996 Murray tractor and the speed of the tractor gets slower the more it is run. Where should I start?
check belt that goes from motor to trans. check pulleys and the bearings in the pulleys for same belt.
Aug 24, 2014 | Murray Garden
I have a 1989 jeep wrangler it does not have a serpentine belt but rather 3 belts i need a diagram showing how those belts are suposed to be routed
Check with Autozone and discuss your problem. They know what they are talking about and have always come up with the right parts or belts for me. I used to be a mechanic in my youth and I never go anywhere else.........
Sep 01, 2012 | 1989 Jeep Wrangler
Belt will not stay on when mower is started; need a diagram for belt for murray model #38608X12C
Hi Barb,
You should have belt keepers/retainers to hold the belt on. Be sure the belt is behind all of these keepers. The retainers are either tabs or posts that look like a bolt with no threads.
Here is a website that includes a diagram for a model close to yours: http://www.ereplacementparts.com/murray-38602x66f-1996-inch-cut-lawn-tractor-parts-c-17887_17888_28152.html
Note that the belt goes around the outside of the two outer pulleys and inside the idler pulley.
If you are still having problems, please reply back.
I hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 30, 2011 | Garden
The mower deck drive belt slipped off the idler pulley on my 42'' Murray riding mower deck because the idler pulley was worn out. I need to know how to loop the belt back around the pulleys after I replace...
www.murray.com
Sep 30, 2009 | Garden
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
