Question about Canon Office Equipment & Supplies
I have an old Canon 6412 which powers on, paper moves thru machine but no image. Trouble is none of the error lights are lighting up. Before I go thru the expense of toner or, worse yet new drum, thought I would ask for expert opinion, I would like to donate this unit to my Church Sunday School but need to get it into working condition if possible. Worse case scenerio and cant get it to work or cost prohibitive, what are options for disposal? Thanks! Alex
  • 52 Answers
This is not a big problem please check the charging unit (the corona wires, the high voltage unit)
Posted on Aug 29, 2010
Error code (E2) or (E 2 2)
E2 is your printer is out of paper or paper does not feed. E 2.X is an error requiring servicing might have occurred. Turn off the machine, and unplug the power cord of the machine from the power supply. After a while, plug the power cord of the machine back in and turn on the machine. If the same error occurs, then the printer needs servicing or some repairs.
Jan 01, 2012 | Canon PIXMA MP150 All-In-One InkJet...
Our Canon jx210p fax keeps saying "chk printer
CHK PRINTER 5100 / SEE MANUAL
Cause Action Movement of the Holder is blocked. Clear the paper jam or foreign object that is preventing the Holder from moving, then turn off the machine and turn it back on again. There may be an obstruction that is not allowing the Holder mechanism to move. Check for any obstruction (paper clip, small object, etc.) and also that the protective tape are removed from the FINE Cartridge. Check also for a paper jam and clear the jam if necessary . Then press [Stop/Reset] and start again. The FINE Cartridge may be defective. Press [Stop/Reset]. Reinstall the FINE Cartridge (see Prepare the Machine ) and start again.In either case, if the error does not clear, try unplugging the fax. Wait several minutes, then plug it back in. Also, try replacing the FINE Cartridge with a new one. An error requiring servicing might have occurred. Turn off the machine, and unplug the power cord of the machine from the power supply. After a while, plug the power cord of the machine back in and turn on the machine. If the same error occurs, contact the service center.
Jul 26, 2011 | Canon FAX JX210P All-In-One Inkjet Printer
Printer stopped working. I just added new ink supply. Alarm light flashes. Printer status says "service error 6A00"--"check printer" "cancel printing and press the ok button." None of this works. And I...
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Apr 05, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I have a Canon MP830. I am getting an error message 6A00 with a blinking alarm light. Cannot use copy or scan funcitons. Eric
Hello
Error 6A00 is a sevice error related to your device, not a user error. This a very good device and should not give you much trouble.
It could be down to use of none canon inks glogging the ourge unit up after time, it could be due to paper or objects in the purge, i would take the covers and inspect the purge and make sure that it moves back and foward. Make sure that the printer is clean on the inside and everything that should be able to
move, can move freely. It is usually a clogging of ink which causes this problem. Hope this can help you.
Best regards
Andrea
Nov 01, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My canon M 160 jammed, I pulled paper thru, now it won't print
E2 is "NO PAPER" error but in most case it's showing when the paper feed is in incorrect position.Check it movement correctly and check for any objects drop in printer.
Jun 14, 2009 | Canon PIXMA MP160 All-In-One Printer
Red light flashing, And little cartridge symbol on printer screen,
hi i,m iskandar how cant solve the trouble for flashing led resume hp deskjet f2180 thanks
i wait yor reply solution
regrads
ISKANDAR
iskandarsugandi@yahoo.com
Jan 23, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Problems with Canon 7500 Laser Class fax
I have Canon 7000 Laser with Error message #330 which said
SET DOCUMENT??? HELP?
Dec 03, 2008 | Canon LaserCLASS 7500 Plain Paper Fax
Cannon Copier image Runner 400/330 series error 051
E 051 problem is registration horizontal position gear is broken. this gear seem to paper pick up deck back side. remove paper pick up deck and see one small moter and see small gear is there u change it u r problem is solved
Mar 21, 2008 | Canon imageRUNNER 210S Copier
Canon 710i
Can you look into the paper tray and actually see if the feed rolls are turning? You may have either a bad paper feed clutch, or the solonoid that releases the feed rollers is bad.
Also the paper tray should move up and down when the paper feeds to move the paper against the rollers. Up to feed down to eliminate paper drag. One of those fingers that raise the tray may be binding against the bottom of the tray not allowing proper movement.
If you can get a flash light and observe what is going on. Then let me know.
Mar 21, 2008 | Canon FAX-L1000 Plain Paper Laser
65 people viewed this question
old marine
old marine
