Question about Philips GoGear SA178 MP3 Player
Won't turn on
I have a Philips GoGeat 512. I was listening to it when I got on my pc. I unplugged my head phones from in and connected it to the pc. The pc recongized it and everything. Then after I got off the pc Pnd unplugged it it won't do anything. It won't turn on or connect to the pc. please help.
  • 3 more comments
  • Anonymous May 09, 2008
    like it wont turn on like i have it in the cumputer and i take it out and it wont turn on
  • Anonymous May 19, 2008
    my mp3 wont turn on like it freeze up
  • wolf72 May 28, 2008
    i did what you said i followed your steps and it did what you said when i unplugged it it still didnt come on
  • Anonymous May 30, 2008
    My battery was low so i had it in my PC for about 2 hours and the battery life was still very low... on the lowest bar and i listened to it for about 30 mins and the battery died, now when i connect it to the PC nothing happens, i cant turn it on and when its in the USB port nothnig shows up on the PC or the player, i think its broke?
  • gatter May 30, 2008
  • 8,596 Answers
This player does not work well with Windows Media Player 11.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
Posted on May 26, 2008
Tuning tv using universal remote control bd 512
Check this link to download the user manual to this remote control. It has all details.
bd 512 instruction manual edited
Feb 06, 2014 | Philips Televison & Video
Is their win7 support for the GoGear SA177
Win7 Operating should see your GoGeat SA177 as a driver.
Just like a memory stick.
Cut and paste few songs to the device any try it out.
Jul 30, 2011 | Philips Computers & Internet
MP3 player won't power up. I was listening to it and it just went off. Thought battery went dead but tried recharging. Nothing happens when I try to power it up. It's a Phillips Model...
Hi ronnie641,
Here is the Support Site for the Philips GoGear Vibe:
http://ow.ly/5QSk4
You can find FAQ's, as well as instructions on how to perform a Repair (see below). A Repair will restore the device as well as update the firmware.
If you have any additional questions, you can reach Philips Consumer Care @ 1-888-744-5477 - an agent can also guide you through the process.
Hope this helps!
REPAIR INSTRUCTIONS: http://ow.ly/5QSon
Use a pen tip or other sharp object to insert the RESET hole gently on the side of the player and connect it again to your PC.
If it is still not recognized, your player may be at fault. Try the Philips Device Manager software.
NOTE: Contents will be removed by using the repair function.
  1. Install the Philips Device Manager and run it with your player connected to your PC. You can download it under the Software & drivers section.
  2. Click the Repair tab in the Device Manager, press and hold the corresponding recovery key on the player when connecting it to your PC.
  3. Follow the PC screen to recover your player.
You can find the recovery key on your player from the below table.
Jul 29, 2011 | Philips MP3 Player
I can not listen with the earphones,when i conect in the front part, but I can listen the music in the spekers . Thanks
Connect the head phone in the port and select head phone in sound hardware .If still sound not come then might be your head phone is faulty.
Sep 29, 2010 | Targa Computers & Internet
No sound through speaker / working through head phones .All mute buttons I can find are unmuted, but still no sounds
Did you check to see if the sound was turned down? If it isn't then you probaby have a loose wire that connects to the speaker. It could also be a motherboard problem. Panasonic has a really good service center that can fix that problem for you.
Nov 12, 2009 | Panasonic CF19 CD/1.06C 10.4 80GB 512 WLS...
Philips SHM3300 Headset
try to unplug your main speakers and replace the head phone, if it still doesn't produce any sound, then you may replace your head phone.
Oct 30, 2008 | Philips SHM3300 Headset
IBM Thinkpad T43 Memory
ok listen listen the answer is this the other memory is right under the keyboard. turn the lappy upside down the screws that hold the keyboard in are the ones mark with two triangle then open the lappy like you would normally for operation use a screw driver flat head is good put it between the bottom left or right corner better yet put it in line withe the down arrow key push the keyboard up as though you are pushing the function key closerto the top then pluck up the keyboard gently as you would a tin of paint gently a cable is there that connect the keyboard to the motherboard disconnect install the memory then work the steps backward
Apr 14, 2008 | IBM ThinkPad T43 Notebook
Device manager
my philipsgogearsa5125/37 it won't let me hear any songs and pictures
Jan 02, 2008 | Philips GoGear HDD6330 MP3 Player
Lock up
Sounds like the ground connection (-ve) to the earphone socket is broken.
When you plug in the earphones, they ground through the control section on the board. Poor sound is another sympton of this problem.
If you have any soldering experience, dismantle the player, and re-solder the 4 connections to the headphone socket.
May 18, 2007 | Philips PSA232 (512 MB) MP3 Player
My sandisk mp3 512 player won´t start
i really dnt kno this happened to me too im tryin to fix it the best thing u can do is call em up on sandisk.com IF u havnt already tried to mess wit it already if u do find out how to fiix it, PLEASE email me at tsingh66@sbcglobal.net
Mar 19, 2007 | SanDisk Sansa m230 MP3 Player
Philips GoGear SA178 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
