Question about Microwave Ovens
Hi,My pressure cooker is not giving whistles.It is happening since two days.It had worked properly for the past 1 year.Safety valve is gud.I cleaned the pressure nozzle.There is not obstruction in pressure nozzle.Vapours are coming out.But when i put the weight over the pressure nozzle,its not giving whistles.Even tried with new gasket.What could be the problem.
  • Microwave Ovens Master
  • 43,501 Answers
Take the vent apart and clean it in vinegar and water solution...there is mineral build up inside that stops it from whistling....
heatman101
Posted on Aug 27, 2010
GE dishwasher GSD6260JSS doesn't clearn as well as when new
water temp should be a minimum 140 degrees at inlet this can be checked with meat thermometer at kitchen faucet,also need proper fill of water entering dishwasher proper water pressure and fill also important for proper cleaning of dishes,if water is slow entering you may have sediment inside fillvalve screen if on well water in this case you will have to disconnect water supply line and take valve apart the screen is in side valve reassemble and test operation...if this does not work you may have to replace inlet vavle
Oct 21, 2012 | Microwave Ovens
Maytag oven will not heat, no gas flow. Broiler works, clock and timer works.
You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works - click here.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 13, 2011 | Maytag Microwave Ovens
Fissler Pressure cooker has steam coming out from the Utimax valve, is this normal?
Hi. Some steam is ok. But when it is running it should be sealed up. The little rocker should be doing it's thing too. Good luck.
Jul 25, 2011 | Microwave Ovens
The induction cooker when put on it shows E6 after about a minute or so and no heating takes place.
There is a error message there, it indicate a problem with your induction cooker. It cause a defective winding wire or circuit controllers your know induction cooker works similar to the principle of electro magnet induction, it give heat to metal cooking pot. I hope I give you a idea regarding what happen to your unit.
Mar 23, 2011 | Microwave Ovens
Prestige Automatic pressure cooker Instruction
You really need the instruction manual for this model to provide you with full information on how to work it, however the recipes will probably be the same as printed in any other Prestige PC that works at 15/10/5 psi.
I have a copy of a 12 page brochure entitled 'Pressure Cooking - The Fact and the Fiction' that Prestige produced when this model was first introduced. In there there is one page of instructions and illustrations devoted to the Automatic. This gives the following four steps :
1. Put your ingredients in - and the liquid.
2. Secure the lid and set the switch. Turn heat up full.
3. When pressure is reached, set timer, move switch to AUTO, lower the heat.
4. When the bell rings, turn heat off - cooker will release steam automatically. Open and serve.
Hope that this helps.
Alan Vickers.
Feb 13, 2011 | Microwave Ovens
Microwave doesnot heat anything
6 years is a good run for a microwave to keep working
as it is basically a high frequency radio transmitter, take it in for a proper diagnosis and a quote
mostly after 6 years there may be a shortage of parts available for repair so keep in mind that it may be cheaper to junk it and get a later model
Mar 08, 2017 | LG Galaxy Countertop Microwave Oven
Have a used cooker-no instructions. What pressure/for how long to cook stuffed peppers?
Hi. 15 psi for 20 minutes. Here is the recipe STUFFED PEPPERS Printed from COOKS.COM
1 lb. hamburger
1/2 c. uncooked rice
Onion
Onion salt
Garlic salt
Celery salt
Tomato sauce
Green peppers
Combine hamburger, rice, onion, seasonings, and a half can of tomato sauce. Stuff mixture into peppers loosely. Dot with butter. Pour remaining tomato sauce over pepper. Place in a pressure cooker. Pour water in to almost cover peppers. Pressure cook for 20 minutes.
Jun 24, 2010 | Microwave Ovens
JUst purchased a Cook's Essentials programmable pressure cooker, but cannot get it to heat. The program mode seems to be working, that is, all thae proper lights light up, but no heat in element whatsoever...
If you're following the instruction manual but it won't heat, and it's within the 30 day return period, I'd take it back to the dealer for a replacement.
If it's past 30 days, but within the warranty period, you'd have to contact the manufacturer via the owner's manual to get it repaired.
Jan 06, 2009 | Microwave Ovens
Microwave Ovens Logo
772 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
