Question about Toshiba Satellite M305D Notebook
Hi, my toahiba satellite m305d s4828 backlight isn't working, i already replaced the lcd inverter but it still didn't work, i dont know what to do anymore
  • 2,567 Answers
The problem might not be with the LCD inverter. There is a possibility that you have a faulty LCD screen cable. The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board.
Please check this possibility.
Posted on Aug 29, 2010
Testimonial: "thanks ill go see if thats the problem i think that is it screen use to kinda turn on and off thank you"
After changing the converter on satellite M305D-S4830 the backlight still very dim
i'm sure you ment inverter..if its working on external screen? it would seem. that you still need it replaced have u checked the ribbon cables?
Nov 23, 2013 | Toshiba Satellite M305D-S4830 Notebook
I have a Toshiba Satellite M305d Laptop. For the longest time the screen would randomly flicker, all of a sudden it doesnt work at all. Also, the VGA output will not work. I replaced the inverter and...
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jun 16, 2012 | Toshiba Satellite M305D-S4829 Notebook
Toshiba satellite m305d-s4828 no bios post, no beep and display I tried to connect to external monitor and still blank I have check the video cable connected from system board to LCD they are good....
remove the ram from the board and turn it on you should hear a beep for no memory detected if no beep then either the motherboard, the processor, or both are shot
Jun 30, 2011 | Computers & Internet
Toshiba satellite p35-s609 screen darken.
It is almost certainly the LCD inverter which is the cause of your issue. It ism ore common for the inverter to develop a fault than a backlight bulb on the LCD (I used to work in a Toshiba repair centre).
Replacing the inverter should be simple, just make sure the unit is powered off with the battery removed so you don't get an electric shock.
Hope this helps,
www.PuterCare.com
Jul 13, 2010 | Toshiba Satellite P35-S609 Notebook
Blank screen
Take a flashlight and shine it on the screen. If you can see an image, you probably need to replace the power inverter board. It supplies power to the backlight.
Jan 23, 2010 | Toshiba Satellite M305D Notebook
Toshiba P105, backlight dont turn on in my lap
If the LCD, inverter etc works in anothe laptop but not in the original laptop then it looks like a motherboard problem, possibly the power supply to the inverter.
Oct 11, 2009 | Toshiba Satellite P105-S921 Laptop PC...
My Toshiba Satellite M305D-S4830's screen will flicker black randomly with no aggrevating and occasionally will fade to white or black completly.
I recommend you to reinstall the display drivers of your laptop as the issue may occur due to the corrupted display drivers.
Uninstall the display drivers from Device Manager.
Expand Display devices.
Right click on the display device and select Uninstall.
On restarting the laptop, windows will detect the device and reinstall the display drivers.
You can even install the display drivers from your notebook support website:
www.csd.toshiba.com
Jun 29, 2009 | Toshiba Satellite M305D-S4828 NoteBook AMD...
Toshiba blank screen
Your LCD backlight is not working. You will either need to get it fixed or have the LCD assembly replaced altogether. If your computer is under warranty, Toshiba will perform this repair. Otherwise, take it to a local service shop.
Jun 05, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite M305D Notebook Logo
336 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
