Question about Toro Lawn Mower With Toro Power Tools
How do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under.
Posted on Jun 30, 2011
  • christi49927
    christi49927 Mar 25, 2012
    I have a Toro 600 recycler and it looks like rivets hold the cable casing down. If you take the bolts off that hold the black plastic fuel and oil tank on and then 4 silver bolts (2 at front and 2 at back) that hold the metal housing usint on. You can then take the metal housing out, turn it over and access the cord to replace.
How to replace drive belt on toro recycler
First thing you need to do remove spark plug wire.. Then I would go to the website for Toro have the serial number ready there you will see the full picture of the way it is then go from there that's the best way with out seeing it. Good luck
Sep 15, 2012 | Toro Lawn Mower With Toro Power Tools
Toro 6.5hp 22" Recycler model#20072 Self-prpel
John, adjusting the cable would have been my first suggestion as well, there are two screws accesible from under the deck to get the black cover off (one of them is in a corner and may be hard to see). Once you get the cover off you may be able to see if you may have a tension problem, belt problem, etc. Goodluck!
Apr 22, 2011 | Toro Power Lawn Mower
Lawn Mower With Toro Power Tools: I have a toro recycler self propelled and it is ge...
look up answers.com on your magneto.thats what makes your spark.
Apr 28, 2010 | Pool & Spa
My toro self propelled isn't self propelling
It may just be a matter of adjusting the cable. Sometimes they dont get them adjusted just right from the factory,heres what you do. Locate the plastic shroud in front of the push mower that covers the drive unit.Determine which screwdriver or torx bit is needed to remove shroud and remove it. After removal you will see a pulley with belt around it, as you pull the handle back to engage self propel you should see the pulley move into the belt to put tension on the belt. You can do this with it running to see if enough tension is being put on the belt,if not, locate the cable end where the small bracket holds the cable in place. Loosen the cable bracket and move cable until you have correct tension again,hope this helps.
Aug 08, 2009 | Garden
Toro 20016 self propel
If you take the wheels off and remove the belt from the small pulley on the the front axle underneath the pulley you should see a small transmission. You usually can split this unit in half . You will see two gears and sometimes one plastic and one metal. The plastic one is usually the culprit. Hope this will help you out. Donnyb60
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
How to remove plastic front wheel drive cover on Toro Recycler
On my Toro recycler, I also had the front drive stop working -- and fixed it after reading the solutions here.
First, the plastic cover on the top deck that goes over the front drive mechanism must be loosened enough to pull it up. Before you can do that, on the underside there is one screw to take out.
Once that's done, all you have to do is pry the plastic cover up enough to see the belt and pulley that make up the front drive assembly. On mine, the belt had simply come off the pulley. Putting the belt back on, then tightening things back up is all it took to put the Toro back in sel-propelled happiness. Good luck!
Mar 07, 2009 | Toro Garden
Cable traction needs adjusted
To adjust the self propel cable, loosen the cable
clamp, pull the cable downward to remove all the slack
then push the cable jacket up 1/8”
and secure with the cable clamp
good luck
Jan 26, 2009 | Toro Lawn Mower With Toro Power Tools
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
1,690 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
