Question about Intermatic Inc. ST01C Digital In-Wall Timer
The screen says "loBat" and I have replaced the batteries 3 times and it still says the same. What is going on?
  • 12,061 Answers
Unfortunately, the Battery Presence & Charge detection circuit, has failed this is common on devices like this. What has happened, usually, is the a series resistor that has gone open circuit, this stops the detection circuit fro properly "Seeing" the battery. This the symptoms you have.
If you were skilled in soldering and can use a meter, you should be able to find the Open Circuit resistor, and replace it. However I wonder if it would be worth the effort? As it is also possible that this is just an underlying symptom of a larger problem as it usually is.
Posted on Aug 28, 2010
Cmos battery error failure
The CMOS (BIOS) battery keeps the computer'a comfiguration and the Date & Time settings in the CMOS (BIOS) chip in its memory. When the CMOS (BIOS) battery is flat these configuration information is lost.
Replace the CMOS battery with a new one, in most cases this battery is a lithium 3 volt battery type CR2032 and it is coin size battery 18mm in dia.(check it to make sure the type of battery is installed on your motherboard).
When you replace this battery then go into the BIOS and set the Date & Time etc.
Jan 26, 2012 | Intel DG31PR Motherboard
Intermatic ST01C is a wall timer for my outside lights. The screen flashes "lobAt" and will not operate properly. I have replaced the batteries 3 times, and no result in stopping the signal. help please
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} ST01C manual:
http://waterheatertimer.org/Intermatic-st01c.pdf
1) Manual shows troubleshooting steps. Since ST01C is battery operated, it will not work on loads farther than 100 feet away. If a wire is buried underground, this can interfere with operation. Other electrical devices can interfere with operation. Check for interference issues.
2) Try reprogramming timer
To program the ST01C:
http://waterheatertimer.org/ST01C-program.html
3) ST01C has 1 year warranty + troubleshooting steps in manual, implying short life expectancy. Similar EJ500 has troubleshooting + 1 year warranty. Similar Intermatic EI600 battery-powered has troubleshooting + 5 year warranty. Each offers 40 programs per week.
3) Other in-wall programmable timers offer 7 on and 7 off events per week. Clock operates on 120V instead of battery. Ttroubleshooting is: reprogram.
http://waterheatertimer.org/Programmable.html#progr
Aug 28, 2010 | Intermatic Inc. ST01C Digital In-Wall...
What does LOBAT on the thermostat stands for?
It appears that your thermostat needs a new battery. It stands for Low Battery.
I hope this helps! :)
Nov 30, 2009 | Heating & Cooling
Our high school has about 40 calculators which have stopped working. We put in new AAA batteries and also replaced the disc battery. In most cases, the screen just won't go on. Any suggestions?
Maybe it is time for your school to graduate to the TI'Nspire technology. Just a joke. OK, it is possible that the screen is too light, and you will have to increase contrast. Here how you do it.
Press the ON button,
1. Press the yellow [2nd] key and release it.
2. Press the [UpArrow] key and release it.
3. Repeat Step1 and Step2 in sequence, until contrast is adequate. Beware that you will have to repeat the cycle several times.
I read that you changed the main batteries and the backup batteries. It should not be done all at one go: Calculator must at all time have either the backup in, or the main batteries in. You may lose informations if you pull them all out.
Hope it helps.
Oct 02, 2009 | Texas Instruments TI-83 Plus Calculator
The phone goes dead when i try to make a call
check tne battry replace f its old weak easy lobat
Jun 29, 2009 | Samsung SGH-J750 Cell Phone
K850i keeps on switchin off
-BeCoUse Your cEllphOnE Is LoBaT?
May 20, 2009 | Sony Ericsson K850i Mobile Phone
IBM ThinkPad 600E 2645 PC
the following data is from the hardware maintenance manual for the thinkpad 600 series and is readily available from http://www.lenovo.com/support
Symptom or error FRU or action, in
sequence
161
Dead battery.
1. Go to “Checking the
backup battery” on
page 12.
2. Backup battery.
3. System board.
163
Time and date were not set.
1. Set time and date.
2. System board.
173
Configuration data was lost.
1. Select OK in the error
screen; then set the
time and date.
2. Backup battery.
3. System board.
192
Fan error.
1. Go to “Testing the
computer” on
page 7.
2. Measure the voltage of
the backup battery. If
the voltage is not
correct, replace the
backup battery.
3. Fan.
4. System board.
Oct 03, 2008 | IBM ThinkPad 600E 2645 Notebook
Sidekick 3
when my sidekick 3 turns on it shows a screen that says " SYSTEM CRASH @10007F54" can anyone help me?
Jul 05, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Intermatic Inc. ST01C Digital In-Wall Timer Logo
314 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
