Question about Sharp Aquos LC-32GD6U 32 in. HD-Ready LCD Television
I'm trying to use my 6 yr old Sharp TV as a remote monitor for my MacBook laptop. The Sharp manual says that port 5 is the correct port for PC hook up. So, I'm hooking up the laptop's mini DVI port to the Sharp port 5 via a DVI cable and adapter. The Mac knows the cable is hooked up, it displays Sharp LCD in the mac menu bar but there is no display on the TV, the TV screen stays black. When I push the "input" key on the remote the TV displays "5 PC, ---X---, --HZ
  • 11,361 Answers
You need to set your MAC video resolution to the native resolution of this TV in PC mode, please read your manual to find out what that is, if the resolution is set too high, the TV will not be able to display it.<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a rel='nofollow' href="http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide">http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a rel='nofollow' href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span>
Posted on Aug 28, 2010
How do I display PC screen onto Sharp TV LC26SB24? I&#39;ve lost TV user manual
Depending on your OS on most computers you need to either add a second monitor output or change the settings to tell the PC to redirect the video output to and external device instead of the PC's screen. Check your OS settings.
Jan 01, 2015 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I cant connect my tv to computer
Hello
All modern TV's can be used as computer monitors - you just need the correct cables and select the correct input on the TV.
What cable are you using to connect your PC to your TV? VGA or HDMI? Your listed TV has both ports but your computer may not have a HDMI port. Either way, connect the correct cable from your PC to your TV and note how the port is labeled.
Turn the TV on and then find the "Input Select" button on the remote and press it until the above port appears on the screen.
If you use the VGA port, you will need to hook up the audio from the PC to the "PC/DVI Audio In" port so the sound will play on the TV speakers.
You can find the manual for your TV here:
http://www.sansuiproducts.com/products.html
Hope this helps!
Nov 09, 2013 | Sansui Televison & Video
I GOT THIS MONITOR/TV FROM DAUGHTER, I DON'T HAVE MANUAL. HOW DO I HOOK IT TO MY COMPUTER TO USE AS MONITOR. WHAT CABLES AND WHAT PORTS? THANK YOU
Tries Element website itself if ur LCD tv model still in the market u can download manual for free not look for their phone number like 1-800..call them pay them a fee they'll send out a copy of the manual to u.U have a LCD monitor now hook up to ur computer right now to used as a monitor now wright?Yes.Take that VGA cable out from ur computer and ur old LCD monitor VGA cable out of the VGA ports just take ur hand and unscrew the VGA cable.Used ur old LCD monitor VGA cable and hook up to the LCD tv VGA port and to ur computer VGA computer graphic card port or computer monitor port hook up the other end.Turn on ur Computer and tv on used the sides button of the tv find one that said INPUT push it a few times should find ur tv mode 1,2.3 ur computer is on as a monitor.
Aug 19, 2011 | Element Electronics FLX3210 32 in. LCD TV
My sharp tv is pc ready. I hook everything up and nothing works. Tried hdmi and also tried RGB-vga cables. If I put cable in hdmi port nothing happens. If I use RGB cable and audio nothing happens. If I...
There are a number of things to check here:
1) Verify that the resolution on the PC is set to a supported level for the TV. Usually the TV will show "no signal" if the resolution is out of range or the message "out of range" will appear.
2) You don't indicate whether you are connecting to a desktop or laptop. If a laptop, you may need to turn on the external monitor. This is done by using the function key and either F5 or F6 (the key should have a picture of a screen on it). Hitting this combination will toggle between the main screen with.without the external monitor.
3) Verify that the TV port is selected correctly (AV1,AV2 etc)
4) You will need a separate cable or the audio regardless of the system type. Also verify that the audio cable is in the corresponding audio input jacks for the video option selected.
If you have completed the above and it still doesn't work, please post the details about the computer being used and the exact cable setup that you have and I'll check into this further.
Thanks,
Dan
Mar 12, 2010 | Sharp LC-19SB25U 19 in. LCD HDTV
Macbook - Lg TV
Take a look at these discussions:
http://macosx.com/forums/hardware-peripherals/304718-connecting-macbook-lg-hdtv-rz-32lz55.html
http://discussions.apple.com/thread.jspa?threadID=1398546
Maybe a solution.
Good luck.
K.
Jan 04, 2010 | Apple MacBook Mac Notebook
Sharp lcd five yr old monitor wont turn on
If the button on the tv doesn't work, and the remote does, its a contact thats broken. If the remote and the button don't work, it can mean that the dead. The only real way to know if its really broken is to call you local, certified by Sharp, repairman to diagnose the problem.
Dec 20, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
I just hooked up my HP Pavilion 9000 Laptop to my Vizio TV and put the TV on correct setting. It is not working on the TV, any ideas? I went on Display setup and kept trying to connect but it says the...
If your laptop has a VGA port, your Vizio needs to have a VGA port too so you can use a standard VGA monitor cable.
If your laptop has a DVI port, you hook it up to the Vizio using a DVI-to-HDMI cable.
And if your laptop has an HDMI port, you hook it up using a standard HDMI cable.
Hope this helps.
Oct 16, 2009 | HP Pavilion dv9000z Notebook
Laptop to pc monitor
Connecting the laptop to an external monitor hooked uip to the VGA connector at the back of the laptop cannot damage the laptop, even if the monitor is connected to a different power supply, as on the VGA port and cable there is not high voltage being carried.
Apr 05, 2009 | Computers & Internet
Sharp Aquos LC-32GD6U 32 in. HD-Ready LCD Television Logo
159 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
