Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
I have a laser 73 in a garage w/ concrete walls w/ no insulation on the walls in Willow, Alaska. This is a cabin for us so we keep this on 50 degrees most of the time. This unit is oversized for the space only 750 sq.ft. For some reason I keep getting moisture collecting in the bottom of the unit causing the blower motor to go out. This is a 2005 model and I had to replace two blower motors already. I have an extention on both the exhaust and intake air pipes. It appears to me that condensation is collecting in the exaust pipe and draining down into the unit. Any suggestions?
  • 674 Answers
Make sure that the flue pipe is angled down outside. I can't remember the angle they recommend, but I think it should slope down about 1/2" for 12" of horizontal run. Also the Laser's are very efficient resulting in some of the flue gas condensing. This will leave some build up behind that reminds me of the stuff you find on a car battery terminal. Let me know if this helps so I can give you more suggestions if necessary.
Posted on Aug 28, 2010
Why is water coming up from my concrete floor?
ground saturation-if no water lines run through there
Jul 17, 2017 | Washing Machines
Totalline thermostat P4740130. Keep getting blank screen
mcdevito75 here Sounds like a faulty thermosat, un --plug a.c unit for a few mintes maybe it"ll recycle, plug back in wall and try again, if not see your local a/c repair shop.
Jun 21, 2010 | Heating & Cooling
Okay my grandma has Toyostove laser 73, its located in her livingroom. She keeps the livingroom entirely shut off from the rest of the house its a medium size house she used over a 100 gallons of oil for...
Ken,
Your grandma may have the room sensor low on the wall. Trying to heat the last foot or so of the room may not be necessary. Even here in Alaska with a 1000 sq ft house I only use 2.1 gallons a day. 100 gallons a month is about 3 gallons a day, that sounds like a lot. Older folks sometimes like it hotter than most. 70 degrees is hot, anything above that will use a lot of fuel.
Tom
Bethel, Alaska
Feb 26, 2010 | Rinnai Toyostove Direct Vent Heater:...
Side by side refrigerator in unheated space not working in cold
Good day,
GE recommends minimum ambient air temp above 55 degrees,
and that's pushing it.
Move it inside.
As an example. If the garage temperature was 10 degrees and the machine was left unplugged. What would the temp be in the fresh food section. If you said 10 degrees, you would be right.
P.S. Insulation does not prevent an area from getting cold, it just delays the time.
Nov 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I need to get replacement parts for my laser 73 stove and no one around seems to carry them? Any ideas?
Any dealer that sells new Toyo stoves should be able to help you.
I don't think the rules of this site will allow me to post the web address of the dealer I use; but typing "Toyotomi heater service" into Google pulled up quite a few dealers.
Hope this helps!
_Helping Hands Services_
- Fairbanks, Alaska -
Oct 27, 2009 | Rinnai Toyostove Direct Vent Heater:...
I was told my Toyostove Laser 72 stove needs to be cleaned. Can i do this myself and what do I do.
I would recomend having a qualified technican service your Toyo.
It IS possible to clean it yourself, but you will want to do it during a time that you aren't needing the heater to keep the space warm.
Certain parts can be hard to tell if they are working as they should if you aren't familar with what you're looking at.
With proper service, your Toyo will operate efficently, and likely last for a long time.
Oct 05, 2009 | Rinnai Toyostove Direct Vent Heater:...
Dumb Question
Mike,
NO, Rinnai and Toyotomi (Laser) are not the same. A simple Google search would make that clear. Now, a new blower motor with case for a Laser 73 comes complete. Fans, motor and gasket all put together, ready to plug in and go.
You would be better off contacting a local dealer for your parts. NO authorized Toyotomi dealer is supposed to sell parts over the internet. A Toyotomi dealership is a valved item. It is meant to help sell and service the Toyotomi product in the dealers local area. It is a great help for someone to be able to call his local dealer and have that guy come right over and help you out.
Saty warm,
Tom Hawkins
Bethel, Alaska
hawkins111@gci.net
Mar 06, 2009 | Rinnai Toyostove Direct Vent Heater:...
Condensation freezing.
Lust extending the exhaust outward a foot should help with the ice on the wall problem. A regular metal stovepipe should be all you'll need.
Jan 13, 2009 | Williams 3003622 Ceramic Wall Mounted...
Laser 30 model won't heat my 24'x24' Garage?
heating and cooling is rated in btu.or could be watts.for your space to be heated quickly to say 70 deg f. you may need a heater with a rating of 36000 btu.it will heat u up then shut off.if you use a smaller heater it will take longer to heat thus using more energy for the same results.
Jan 07, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
55 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
