Question about Kenmore 22422 Top Load Washer
Filling With Water
When filling the washer machine, the washer machine keeps filling until it overflows. Do i need to replace a pressure sensor or some kind of water meeter so that the washer machine "clicks" and begins to wash the load instead of overfilling?
When I start filling water in my washing machine, after filling level completion the spinning cycle start but filling of water does not stop and have to turn off the water from the main supply hose only, plz suggest.....!
  • 1 more comment
  • Anonymous Jul 22, 2008
    Had to turn off water faucets to stop it even after unplugging the washer it kept filling.
    could it be inlet valve..
    or defective switch. The control dial would not work to stop it.
    Later after emptying the tub by baling by hand.. Was able to get it to spin.
    Dryer is sqeaking louly when it first starts up. Gets better after it runs a bit.
    Lubrication or part needed.
  • Anonymous Aug 30, 2008
    coldwater stops but hot keeps on running in and over have to turn off at faucet overfills
  • Anonymous Mar 07, 2009
    westinghouse top loading washer keeps filling, overflows, and wont continue.
  • 550 Answers
If the water continues when electricity is discontinued the soleoid valve is jammed open, a fleck of rust or something, not designed to be repaired, it is easier and cheaper to replace. they are a standard part that fits 99% of all washers ~$10-20 at the local parts guy.
Usually only the cold solenoid has failed. it gets used more often.
If you are like me and only use cold water, swap the hoses on the taps, and swap the wire connectors on the solenoid valves, so the former hot is now cold, and you will get about the same number of years before you have to replace anything
Posted on Jul 29, 2008
I recently had the same problem. I checked the end of the air hose coming from the tub. It had a tear in it right at the connection. I just cut off the hose at the tear and placed the hose back on the connection.
Posted on Jul 18, 2008
  • 975 Answers
Yes !! you need to replace the sensor meter , usually located on the side of the tub , open washer and look for a sensor glued to the tub with a long clear hose that runs up to the water set knob, hope this helps AJ
Posted on May 06, 2008
Water level control switch not working. even i set water level to very low it just keeps filling and has overflowed. i am guessing that the switch needs to be replaced.
It depending on exactly what your seeing that will determine the problem.
Does your washer start agitating and keep filling?? if yes it does start agitating and the water continuies to fill try disconnectiing the power and if it keeps filling what would be wrong is that the water inlet valve is sticking open and it would need to replaced
If the washer continues to fill and does not start agaitating would be a defective water level switch as you suspect it may be.If ya disconnect the power and it STOPS filling replace the water level(pressure) switch.
GENE
Oct 02, 2011 | Kenmore 24032\24036 Top Load Washer
My whilpool calypso continues to fill machine with water until it overflows.
What is happening is that the fill sensor is apparently not working. The washer will continue filling until it overflows the washer!
Replace the pressure switch. This will solve your problem and cost is about $35.00
Before replacing the switch check the hose which comes to the switch also
It is possible that hose has a hole in it or has come undone. If there is no pressure in the hose, then it wont actuate the switch, and thus fill forever.
If your air tube is in good shape, it could be the switch itself, it may be adjustable.
Jul 22, 2010 | Washing Machines
Why do the stackable washers always overflow with water. Is it a sensor problem or what?
Overflowing can be caused by a faulty pressure switch or tube from switch to the tub. It is operated by air pressure from water filling in the tub. If this does not activate then the inlet valve will continue to allow water to enter the machine. If it is overflowing during spin only it is most likely something obstructing the pump. If it is filling the tub even when the machine is off the problem is the inlet valve.
Jun 28, 2010 | Maytag LSE7806A Top Load Stacked...
My washing machine, dispite what water level it is set on, keeps filling and filling until it overflows. What is the problem?
Trash and sand is in the bottom of the tub blocking the pressure tube.
Remove the tube from the water level switch and blow through it to get the seddiment out. Replace the tube securely empty any standing water and retry' screw%20removal.jpg
Oct 24, 2009 | Kenmore 22422 Top Load Washer
Water doesn't stop filling tub and tub overflows
the water level sensor is not working and needs to be replaced
Aug 31, 2009 | Washing Machines
Water Overflows from washer
Hello,Sounds like a problem with either the inlet valve or the pressure switch, way to determine which on is while it is filling pull the plug..if water keeps filling it's the inlet valve..if it stops filling it's the pressure switch..If you have any other questions or concerns please feel free to comment again..good luck!! Mike
Aug 18, 2009 | Kenmore Washing Machines
Fill will not stop
you may have a problem with your pressure switch. or sometimes they call it the water level switch.
try to use it in the small level and see if it would stop filling around medium or large quantities of water.
if it would stop filling , then replace the water level sensor.
tnx 4 using fixya,
drcool
Oct 18, 2008 | GE WBB4500EWW Top Load Washer
Filling With Water
"preesure switch" built into controller, remove 2 screws behind console nad check the clear hose hasnt become diconnected, or perhaps has a crack in it not able to "read" water level
Mar 04, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washer constantly fills with hot water even when turned off.
Sounds like a bad mixing valve. To verify that it is the valve you need to turn off the washer when it is filling. If water keeps running, replace the valve, Cost is under $50. for most washers.
Jan 03, 2008 | Washing Machines
Kenmore 22422 Top Load Washer Logo
254 people viewed this question
Sal De
fordexpert
Robert Rankin
