Question about Frigidaire FDE336RE Dryer
My dryer was running but i had to replace the belt. Now the dryer will not come on
    President:
  • 3,074 Answers
Door switch, either not engaging or wires not hooked up.
Posted on Aug 27, 2010
Magtag dryer drum will not turn is there a belt that needs to be replaced
If you hear the motor run, but the drum doesn't turn, it's most likely a broken belt.
Mar 11, 2014 | Maytag Neptune MDE7500AY Electric Dryer
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
Jul 08, 2011 | Kenmore 63932 Electric Dryer
My GE DSXH43EA2WW Dryer is making a squeaking sound when running. Tends to get less noisey as the dryer continues to run
Hello
You will need to replace the dryer belt and inspect the belt rollers while you have it apart. If you go to the web link below it explains how to take apart the dryer to replace the belt, it has additional links to pictures and diagrams within the instructions. The first link is for replacement parts with diagrams of the dryer. Here is that link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130504&diagram_id=21844825#d21844825
The next link is the Do It Yourself Article on replacing the dryer drum belt. while you have it apart remember clean the lint and dirt out of the cabinet interior. Here is the repair link:
http://www.applianceaid.com/ge-dryers.html#belt
Jan 14, 2011 | Dryers
The motore will run, but it is not spinning. The motor smells hot when it is running and not spinning.
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt.
Here is a link to the belt.
Jan 06, 2011 | Amana ALE443RAW Gas Dryer
Kenmore solid state dryer. was squealing while running. now drum stops and starts. still squeals
belt, idler pulley, drum glide/rollers:
belt/idler pulley:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
rollers/glides:
http://www.partselect.com/dryer+replace-glides+repair.htm
belt configuration
http://www.applianceaid.com/images/belt-config.JPG
Dec 03, 2010 | Kenmore Dryers
The dryer heats but the drum does not turn. sherryd863@aol.com
The belt is likely needs replacing. Before taking it apart turn the dryer on and listen for the sound of the motor running. If it is the belt is broken. If not it could be several things ie; motor,timer, shorted or open wire. Here is a link for the belt Dryer belt replacement The belt is inexpensive and easy to replace. You can also watch videos of the other possible problems at the same site.
Oct 21, 2010 | Maytag PYE4557A Dryer
When belt breaks is there an automatic shut of switch because the dryer will not run?
Yes on MOST dryers there is a belt safety switch. It is there to prevent you from using the dryer with a broken belt. (i.e heat but does not tumble) When the belt breaks the idler pulley arm drops down and trips the safety switch.
If you need help with parts, and replacement belt procurement / owner replacement of the belt, we need your model number please so we can pass you the correct information.
Just respond here and someone will help you.
Kelly
Aug 16, 2010 | Dryers
Dryer runs but wont tumble
Try checking to see if the dryer belt is broken, the dryer belt wraps around the drum and goes to a motor at the bottom of the dryer that turns the drum, if so you can usually get a replacement belt from the maker of your dryer by visiting there website.
Mar 11, 2009 | Danby DCD5505W Electric Dryer
Dryers Logo
14 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
