GE WASHER WPSF4170V1WW
THIS WASHER WILL INTERMITTENLY STOP IN MIDDLE OF WASH AND
NOTHING YOU DO WILL TURN IT BACK ON. LET IT SET AND SEVERAL HOURS TO 3 DAYS YOU TRY TO TURN IT ON AND IT WILL COME ON.
WE HAVE HAD A REPAIRMAN OUT TWICE AND IT WORKS WHEN HE
GETS TO IT.
  • 172 Answers
Hi rondean,
I would imagine your atc sensor or atc contol board could be causing the problem.
1st make sure you are getting water to the machine hot and cold. If you water valve is not opening for one or the other it would be the water valve. To check the valve start the washer on a cycle and select cold wash feel the water, then turn it over to hot and feel again. If both are working then you will most likely need the ATC sensor part #WH12X10016 $48.00 or you will need the ATC control board part #WH12X10045 $118.00 I would start with the sensor they usually are the problem in this situation. Good luck to you. Mike
Posted on May 07, 2008
Why does my washer stop working in the middle of wash cycle and then go dead and no response?
Should get some one to look at it. If there is a hot smell could be a short someplace.
Dec 22, 2016 | Kenmore Washing Machines
My the front load washer model gcvh6900jww has the red lock on the display. I accidentally held the start button for a few seconds and it locked. I tried holding the start button again for up to 20 seconds...
  1. Found This HelpfulSometimes something will go wrong in your washing machine that will cause it to lock up or stall. An overloaded washer or a brief power surge can cause this. The washer may not drain or spin properly, or it may stop the cycle in the middle of the wash. Another cause may be that the washer was stopped before the cycle was able to complete. In this case, the washer will spin and drain over the next 24 hours, but it will stall before reaching the final spin. GE has two simple methods to reset the controls
For Newer Washers:
    • 1 Unplug the washer.
    • 2 Twist the control dial around the cycle settings.
    • 3 Place the dial on any setting other than the final spin.
    • 4 Ensure that the water line is securely attached to the washer.
    • 5 Plug the washer back into the wall (making sure it has gone at least 30 seconds without power).
Nov 11, 2014 | Washing Machines
Output drainage error
YOU HAVE TO UNCLOG THE FILTER AND THE WATER PUMP ITSELF. CHECK TO MAKE SURE THE WATER PUMP PROPELLER IS NOT OBSTRUCTED? CAN U TURN THE PROPELLER BY HAND
Mar 25, 2014 | Asko W6903W Front Load Stacked Washer /...
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
Jan 17, 2014 | Washing Machines
Machine has no lights or power.
Our Whirlpool washer is GVW9959KQ0, bought in September 2001, in September 2010 it had the problem as follow. When the panel was lite up, it was always set at "44" minute, NORMAL wash, no touch area is responsive, not even STOP or START. I could turn off the panel completely by pressing STOP and "Whitest white" in sequence quickly. When the panel was shut off, I could turn on the panel again by just pressing "STOP"; But the panel was back to "44" minute, NORMAL wash. Unplugging the power did not help (see as follow). That was the washer life for a couple weeks. We left it w/o power for 24 hours, it worked again normally just for 1 wash, and it was back again to the zombie mode; left it again for 24 hours, no luck, left it again for 24 hours, worked again for just one wash. We managed to wash 3 loads during the 2-week period (just 1 wash per time). Since the washing functionality sounds and looks working well to me, I thought that the panel might be the culprit. Finally we ordered Control Panel Assembly (Parts AP3884746, it is just the panel part where we touch for washing selections w/o electronic boards behind it) at appliancepartspros.com (cost $178 regular S
Apr 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer stops several times in the middle of cycle
possibly it could be your un-balance switch getting very sensitive to any type of movement of the machine, normally they only actuate during the spin cycle when you have a very off balanced load of clothes
Oct 03, 2009 | GE Profile Prodigy WPSE4200A
My Sears 500 washing machine stops in middle of wash cycle.
timer problem or maybe the lid switch is going bad. Im curious if the motor is getting hot and shutting down... go to whirlpoolpartssurplus.com call .. ask for mark
Jun 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My front loader has stopped in the middle of the cycle.
you need to clean your pump something is stuck not allowing the pump to drain
Dec 25, 2008 | Washing Machines
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
104 people viewed this question
Top Washing Machines Experts
