Question about Brother IntelliFAX 2800 Laser Fax
Brother intelli fax 2800
I can send but when receiving all i get is a blank sheet ( now i got 1 that came through with text out of 10 tries)
    Scholar:
  • 159 Answers
It could be that your sending fax is sending paper not facing the scanner. In that case tell them to turn the paper over to send. Other than that, it could be that the telephone lines are so dirty that the fax protocl fails at the check frame signal. You will have to adjust the equalisation and line attenuation. Don't count on the telephone company to help you, they always want you to do everything 1st before they will admit to any fault on their part.
Posted on May 10, 2008
Brother mfc-7840w won't receive fax
The first thing that I would try multiple people to ask them to fax you.Sometimes the 2 machines don't "sync".This is a toll free fax test number that I always use to check my machines..1-888-473-2963.Just write the words "FAX TEST" in large letters on a blank sheet of paper..fax it to that number...leave the line open...you should get a fax back in about a minute.If you get a fax back...your machine is fine...let me know if this was helpful....thanks.
Dec 14, 2011 | Brother MFC 7840W Printer
Line goes through page when fax is sent
Open up the document feeder and clean the small glass. If the line is more than 1/4 inch wide you have a bad scanner block.
May 13, 2010 | Brother IntelliFAX 2800 Laser Fax
Printing blank pages when receiving fax
Ask if the ones sending are sending legal size, it may be using 2 sheets to get all from a legal size document.
Jul 29, 2009 | Brother MFC-8460N All-In-One Printer
I have a Brother Intellifax 2800 and it can send faxes but just rings and rings and won't receive them.
what does the display read. If you want the fax to auto answer. the display needs to read ( fax only). to chang this setting if not reading that massage press the receive mode button till fax only is in the display
Jan 30, 2009 | Brother IntelliFAX 2800 Laser Fax
BROTHER FAX MACHINE 2800
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Sending one printed fax, yet reciever gets additional 3 blank sheets.
Open up the document feeder and look for a trapped down or sluggish switch
Oct 25, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Cant receive faxes
Set your fax machine for AUTO RECEIVE. Unplug power cord and plug back in.
Sep 05, 2008 | Brother IntelliFAX 4100 Laser Fax
Setup
Yes, just set the receive mode to "manual" the machine will then just ring when a fax is incoming and not print. It may become annoying after a while because the sending machine will try to send numerous times. You can get around this by setting the ring volume to mute.
Jun 06, 2008 | Brother IntelliFAX 2800 Laser Fax
Bad print with repeated text on fax or copies
Make a copy and shut the power off or open a door when the paper is 1/2 way into the machine. You are just basically going to have to try to time it. When you hear paper being fed into your machine (the blank paper from the tray) count about 3-5 seconds and then open a door on the machine or shut the power off. IF you have timed it correctly, the paper should be 1/4 - 1/2 way through the machine. Remove the jammed paper **** But be careful..... The toner is NOT FUSED at this point so it will rub off if you brush it up against your clothes or hands. If the image is doubled at this point.. then its the drum unit. If the image is good at this point, then it is probably your fuser.
Hope this helps.
Good luck.
Mac =)
Apr 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
59 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
