When playing a DVD, I can only hear the music in the movie. All the talking, and background noise can not be heard. Not sure how to fix!!! please help!!!!
There are a few things that may cause this to happen. First I would check your connections for your center channel speaker. in movies with 5.1 surround sound almost all the vocal tracks come out of the center channel.
Otherwise there maybe an issue with the volume levels for the center channel as well, these can normally be adjusted through the setup of your home theater system.
You need to change to sound setting on your amp to 'multi channel in' or dts, depending on what you are trying to watch. Also make sure all speakers are polarised correclty ie +/+ -/-.
Hi, What you are encountering is your receivers playback of a Dolby digital signal with out the proper amount of speakers attached. When using a 5.1 or higher system you must have at least 5 speakers connected. You need front left & right main speakers, then you need a center channel for the voices to play thru. then you want left & right rear speakers for the surround effect. It is possible though to do without these, you just switch the receivers sound field mode from theatre or movie to stereo. I hope this helps, write back to let us know if we did or if we can be of more help and thanks for choosing FixYa,good luck Prodzilla
on some dvd players and surround sound systems have a thing called DRC (dynamic range compression) you can us that and it will help it a little. i have come across the same problem but im after a digital on to run with plex or vlc on a mac. im having to route it through protools to use a compressor on there, but thats eating my resources.
Coby dvd plays background music and all previews( music and voices ) but the actual movie we cannot hear voices only back voices and music can be heard.
Try adjusting the sound on the tv. If you go into the "user" audio options you can select between normal and True Surround SXT. That may work. Otherwise, try playing with your dvd player's options. The problem I'm having is the tv plays the sound before the picture.
Sounds to me like your center speaker is either not connected, or somehow not working. The not working part could be explained by a failed speaker or, possibly a failed amp in the unit.
I have the same problem. I can hear the background noise but no dialogue!
