Question about Alpine CDA-9815 CD Player
CDA-9815 NEED TO KNOW WHERE TO CONNECT PINK/BLACK AND THE ORANGE WIRE I HAVE NO AUDUIO
    Genius:
  • 1,224 Answers
Dont connect the pink/black wire just trouble these are signal interupt lead wires cap and tape off and the orange wire is the dimmer wire for when you turn your lights on and off
Posted on May 07, 2008
I have a question i have a alpine cda 9847 i color couted the wires and still no power on the unit in the car checked fuses not fuses is the wireing wrong? i even tryed to put the yellow onto the red and...
Confirm this wiring for 2000 Nissan Altima Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Pink
Radio Switched 12V+ Wire: Blue
Radio Ground Wire: Chassis
Radio Illumination Wire: Red/Green
Radio Dimmer Wire: Red/Yellow
Radio Power Antenna Trigger Wire: Green/White
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 4′ x 6′ Speakers
Front Speakers Location: Doors
Left Front Speaker Wire (+): Brown
Left Front Speaker Wire (-): Black/Red
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Black/Yellow
Rear Speakers Size: 6 1/2′ Speakers
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Orange
Left Rear Speaker Wire (-): Black/Pink
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Black/White
Hope helps.
Sep 26, 2011 | Alpine CDA-9847 CD Player
I need to know what wires i am lookin for to install new speakers
This should help.
1989-91 Ford Thunderbird Stereo Wiring Constant 12V+ Green/Yellow Switched 12V+ Yellow/Black Ground Black/Light Green Illumination Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Green Left Front (-) Black/White Right Front (+) White/Green Right Front (-) Black/White Rear Speakers 5" x 7" Side Panels Left Rear (+) Pink/Green Left Rear (-) Pink/Blue Right Rear (+) Pink/Blue Right Rear (-) Green/Orange
Aug 20, 2011 | 1990 Ford Thunderbird
I need to know how to hook up an alpine CDA-9833 stereo into a 1993 dodge dakota without a wiring harness i just want to hook the wires together and i dont know which wire goes to the other all the colors...
Please let me know if you have any questions, and thanks for using FixYa.
1993 Dodge Dakota CDA-9833
Car Radio Battery Constant 12v+ Wire: Red yellow
Car Radio Accessory Switched 12v+ Wire: Red/White red
Car Radio Ground Wire: Black black
Car Stereo Dimmer Wire: Orange (tape this wire off) none
Left Front Speaker Positive Wire (+): Blue/White white
Left Front Speaker Negative Wire (-): Black white/black
Right Front Speaker Positive Wire (+): Purple gray
Right Front Speaker Negative Wire (-): Green gray/black
Left Rear Speaker Positive Wire (+): Black/Yellow green
Left Rear Speaker Negative Wire (-): Gray green/black
Right Rear Speaker Positive Wire (+): Blue/White purple
Right Rear Speaker Negative Wire (-): Blue/Orange purple/black
May 09, 2011 | Alpine Car Audio & Video
1993 dodge shadow radio wire diagram i have a problem with my instrument lights on the dash board speed,gas,temp,gages lights will not come on the radio light is on and it plays and works good but i have...
Hello! I will assume you are connecting a factory radio for your 1993 Shadow.
Remove the Orange wire from ground...Listed below is wiring from car to radio; You may need this one day...You are correct; There isn't a dimmer wire...The Orange wire, from the radio, connects to the Orange/White of the vehicle...Grounding the Orange wire is causing your problem...
1993 Shadow...Orange/ White=Illumination...Red=Hot at all times...Red/White=Switched 12volts...Black=Ground
Factory radio...Orange=Illumination...Pink=Hot at all times... Red/White=Switched 12volts...Black=Gnd.
Car; Orange/White to Orange of radio
Red To Pink
Red/White To Red/White
Black To Black
Let me know how you make out..
Guru...............saailer
Feb 04, 2010 | Car Audio & Video
What can i use the auxillary cable for
yes you can connect it to an ipod/iphone or anything with an aux outlet. Some require an adapter to the plug but it'll still work.
Feb 21, 2009 | Alpine CDA-9815 CD Player
Need pinout for Alpine CDA-7940 head unit
facing the back of the 7940 the top left corner is pin 16 the top right corner is pin 9. The bottom left is pin 8 and the bottom right is pin 1. Only a few of the 16 pins are used due to this unit only having pre-outs, no internal amplifier on this unit. Pin 1 red (ignition), Pin 2 pink/black (interrupt), Pin 3 orange (Illumination), Pin 8 black (ground), Pin 9 blue (power antenna), Pin 10 blue/white (remote turn on), Pin 16 yellow (battery).
Feb 21, 2009 | Alpine CDA-7940
Connecting wireS ..
pink is cell phone mute and orange is illumination or dimmer. both are not needed for proper operation just be sure to take them off good if you don't use them.
for the most boom out of your kenwood subs go with a nice ported mdf box with the correct air space for your subs. this will make a big difference over just throwing them in any old box. i prefer slot ported boxes over round ports for looks and sound.
Nov 18, 2008 | Pioneer Premier DEH-P960MP CD Player
Wiring
According to the wiring diagram, it is for an Audio Interrupt.
Which means, if you have a car kit, bluetooth, or wired, you can connect this wire to it so the Head Unit will MUTE or Attenuate.
If you dont have a car kit, you dont need to connect it to anything.
Best of Luck.
Oct 15, 2007 | Alpine CDA-9827 CD Player
Alpine CDA-9815 CD Player Logo
259 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
