Question about Tools & Hardware - Others
I HAVE A STANLEY H-61-A DOVETAIL JIG. WHAT ROUTER COMPONENTS DO I NEED TO BE ABLE TO USE THE JIG?
2 Suggested Answers
atthings
  • 59 Answers
SOURCE: what is the router bit depth for a shop fox
Usually with router dovetail jigs one has to find the depth by trial and error as the fitting is very critical and any discrepancy doubles as the cut is on both sides of the joint.
I think you may have to play this game.
You will need offcuts of the same size as the finished work that are long enough to go into the clamps of the device and then just fit the joint by trial and error. It is the way we do it in the trade. Sharpening of the cutter and different thicknesses of wood all affect the fit of the joint.
If my memory serves me raising the cutter up toward the machine makes the joint looser and lowering it makes it tighter. If I was in my workshop with the machine in my hand I would remember for sure
Posted on Jun 03, 2010
How do I get a instruction manual for Stanley dovetail model 82913.01?
Go to the place where you bought it and see if they can get you the manual.
Feb 13, 2015 | Stanley Hardware & Accessories
How to use a Stanley 92870dovetail jig
Sir,
There is an interesting man I believe can stimulate your enthusiasm to be a success. Please? Take the time to travel to this link and watch this short but novel approach to building drawers.
Frank Klausz Dovetail Drawer DVD intro
As far as your saw. I would build a base jig to match the depth and width of your work piece, follow your layout leaving half the line. look over Kluasz' library and your sure to be as wide eyed and smiling as you will when your projects come together.
I have always advocated. New wood smells good. Fare . Well.
Apr 26, 2014 | Saws
Is the Dewalt dovetail jig 6212 any easer than a Leigh jig as im stuck at the moment what to buy?
This is strictly a personal preferance but I would go with the Dewalt.Ihave been using a large variety of tools and equipment for forty years and I firmly believe in Dewalt and Milwaukee. Thank you.
Mar 11, 2011 | Garden
Are the 7 degree dovetail bits, that come with the jig, the only size that can be used or can a 9 degree bit be used?
Hi, W/D at your service.
Apparently, there are several types of bits compatible with your model.
Here's a link that gives you a better idea:
http://www.toolup.com/porter-cable_4216_12-deluxe-dovetail-jig-combination-kit.aspx
Best regards, --W/D--
Feb 23, 2011 | Porter Cable Porter-Cable 4216 12" Deluxe...
Where can I purchase an owner's manual for a Craftsman dovetail jig Model # 315-25710 A2044? Virgil
You might check this out, I found it in another forum. It looks like Ryobi made this dovetail jig for Sears.
1-800-525-2579 is their customer service line. I would ask for Ryobi Tech Services.
Nov 22, 2010 | Craftsman Saws
What is the router bit depth for a shop fox dovetail jig
May 31, 2010 | Tools & Hardware - Others
Dovetail leave a 'light gap'
This may not be related to your jig. It may be movement in the vertical axis resulting from:
  1. The router bearings being worn allowing the bit to move up and down.
  2. The router bearings worn allowing the spindle to deflect side to side which changes the bit height slightly (cuts on the edges, making the cut a hair deeper).
  3. The router collet or router spindle worn, allowing the bit to move during cuts.
  4. The jig guide plate deflecting or no longer flat.
  5. Excess vibration in the router causing the wood to move in the jig.
To check the bearings; try routing the cut with a straight bit first to clear the wood for the dovetail bit. Then cut with the dovetail bit (a new one preferably) using very light feed pressure. Is the joint tighter? If so then the bearings are worn. Have the router serviced or replace it.
Check the end-play by pulling on the router shaft, does it wiggle slightly in and out? If so this is your problem. Have the router serviced or replace it.
Be sure the wood is flat and the faces planed parallel, if they aren't the dovetail line will be straight but when you assemble there will be slight end gaps in sections of the dovetail.
Feb 23, 2009 | Porter Cable Porter-Cable 4216 12" Deluxe...
Need a manual for PC omni jig- original model
You will need your model #
Here is where to get your manual
http://www.dewaltservicenet.com/
Good luck and let me know if I helped
Jan 06, 2009 | Porter Cable 55160 16 Inch Omnijig...
Tools & Hardware - Others Logo
256 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
