Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Screen is too blue
When it's first turned on the screen is okay. Then after a while, it goes bluish. For a year or two, I saw the blue retrace lines. Now it's too blue. Anyone know how to adjust the color guns? It's like I just need to turn the blue level down.
  • Anonymous May 21, 2008
    tv has a blue shadow
  • 84 Answers
You will have to take the front cover off, usually 3-6 screws holding from the back, when it does come off there will be wires to the control panel attached still. you will also have another panel to undo. after that there will be a block with 3 focus controls and 3 screen controls marked b g and r for the three colors. The blue screen control is the one you are looking for, be very careful the slightesr turn has huge response including shuting the tv off when you turn it the wrong direction to far
Posted on May 18, 2008
I have a Mitsi WS-65807 65" Played Wii for about two hours. Lost sound then picture. Now it wont turn on. Just get a warped bluish screen with lines. Any Suggestions?
Well i need more info. have you tried unplugging the tv for around 60 seconds? Was the "warped bluish screen" right before it died. Or is this when you turn it on it happens?(Bluish screen)? Because if no power at all and no picture at all. Could be Power supply. If you have some sort of picture with blue lines that are stable? You have a convergence problem. Get back to me with info i can help.
Dec 26, 2010 | Mitsubishi WS-65807 65" Rear Projection...
Tip
White Raster with thin lines; Sound Ok.
White raster with retrace lines: No picture, Sound OK
(picture tube based telivisions.)
It is a common fault to occur in most of the CRT based telvisions, regardless of which brand it is. There will be sound OK, and a bright screen with thin white horizontal lines across; at about an inch space, all over the screen area. This fault may occur along with colur shades also, like blue screen with white retrace line, red screen with white retrace lines, green screen with white retrace lines. Let us take the first case. A white raster with white thin retrace line acorss the screen. These are call vertcial retrace lines technically. To make it mor understand, we have to go to some picture tube electrode details. There are three colour cathodes for a colour picture tube, Red, Blue and Green. Two girds are there called Focus and Screen. Focus grid is supplied with focus voltage which in turn determine the cocus of picture, and screen grid is supplied with screen volrage which determine the emission of the picture tube; in short. There is a final anode to all the picture tubes, which supplied with Extra High Tension voltage, can be located at the top side of the picture tube, to which the EHT voltage from LOT is connected with the help of rubber ****** and clip. Without these three voltages, EHT, Screen and Fcous, no raster will be produced. Therefore in our case, there is a raster, so, horizontal output section including Line Output Transformer [LOT] is functioning well, and as far as sound is there, tuner and video IF section are working well. In fact, all other section except, video output section is working properly.
There are three cathode points on the base card, marked as Bk, Rk and Gk. Check the voltages of these three cathodes. In our case, it will be very low or approximately equal to zero. When cathode voltages goes low, emission of the CRT increases, is the reason. There must be a voltage between 120 and 135VDC at these points. Find out the reason for this voltage drop is the next step. The video drive voltages in most TVs comes from LOT windings, after rectification and filtering. There will be one reisitor of low value, say one Ohms or so, will be connected series with this winding, in between diode and winding. Check the voltage at the cathode of this rectifier diode first. If found low replace the diode and the smoothin capcitor. The smoothing capacitor will be between 33 and 47MFD 250VDC rating. Replace both of them. If there is volatge, say 200VDC or so, check whether this voltage comes to the CRT base board or not, If not, check the conducting wire, serial resistors; if used for open. There is no chance of transistor shortage at this time as the raster we see is white. If raser we see have a specific colour predominent, that is green, blue or red, check the revalent video out transistors and replace it. It is best to replace all the three video output transisors at the same time with same batch and number.
on Apr 18, 2011 | Televison & Video
How do we set the g2 voltage properly
turn blue black to off. turn tv to av mode. then adjust g2..until retrace lines appear on the screen.then decrease the g2 until the retrace lines disappear.
Apr 07, 2010 | Orion STV2763 27" TV
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
Lines on the screen
Are they thin, white lines running east to west? If so, they are called retrace lines and indicate that the screen settings for the picture tubes is set too high or there may be a mal-function of the CRT driver circuitry. Try adjusting the screen controls which are located behind the front grill of the TV behind an access panel. Once you remove the grill and access panel, you'll see a small control assembly the has two sets of controls. Three for adjusting the red, green, and blue focus, the other, the red, blue, and green screen controls. To adjust correctly, put the TV on an unused input(dark, blank picture) and adjust until there are no visable retrace lines or color in the image.
michtech
Feb 14, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Sony 65 inch screen tv
The lines you saw, i;m sure they are the ones called retrace lines but know the failure could be located on the red CRT board. Most likely the video amplifier is defective and not necessarily the CRT.
What is the model number of your TV?
Jun 17, 2008 | Televison & Video
JVC tv fault
if there are no retrace lines you possible have a video ic fault.
Mar 27, 2008 | Televison & Video
Blue and red arched lines on screen when background dark
Sounds like you are describing retrace lines that could indicate that your CRTs or something in the drive circuits are bad.. Check the resistors on the CRT sockets to see if they are in tolerance. If they are try turning the red and blue screen adjustments down just a little this should take the lines away. You will however be needing service in the not to far future. Turning the screens down should help if the resistors check out. Let me know if you need anything further.
Jan 31, 2008 | Sony KP-48S35 48" Rear Projection...
BLUE SCREEN
I got this Sony KP-57WS500 57 in TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 25, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51HW40
I had the same problem with mine 2 years ago (TV was 1.5 years old at that time) I had extended warranty on TV and it was fixed by Sony at no cost to me. Now yesterday I have another problem with it. All of a sudden screen went BLUE. No Sound either. It could be the CRT (That's what I read here) Out of luck this time. Will call local Repair shop (70 miles away) and see how much it will cost to fix it. Good luck.
May 31, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
76 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
