Question about Whirlpool Duet GHW9150P Front Load Washer
Do you have instruction how to replace the whirpool duet door seal (boot)? modal number is wfw9400sw01. ser#csu2405380
  • 4,323 Answers
Hi
Please see this video link to replace the door seal on your washer---
Please post for further assistance. Hope this helps...
Daniel
Posted on Aug 28, 2010
Replacement: tub seal bellow/Whirpool Duet mod.#GHW9150PWO
Hi
Thanks for using FixYa. You can buy the tub seal bellow for your Whirlpool Duet from this link. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Leak/boot tear in whirlpool duet washer
The front door seal is referred to as the "bellow". They will wear out with age and may become mishapened from repeated pressure from the door being closed. Over time the bellow can stretch or develop rips and tears and begin to leak. If the bellow is leaking, or no longer providing a good seal, it must be replaced. This will cause water to puddle under the front of the washer and inside the cabinet. The following link explains how to access and replace one:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and have great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If the model number is correct, the part number is 8182119.
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: If you leave the door OPEN between washes this will help prevent constant pressure on the door seal which can stretch it out of shape over time. It is also beneficial to allow the wash tub to air out to prevent mold and mildew from forming. In addition, overloading the washer can contribute to premature wear and tear on the bellow which can lead to rips, tears and possible dislodging from the bellow clamp seals. Always follow the manufacturer's recommendations for loading in your owner's manual.
Apr 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer will not start . Hear a clicking noise then receive DL F fault
The clicking sound is coming from the door lock/switch assembly trying to lock the door but it cannot. After six trials, the error code "FdL" shows up on the display. Press PAUSE/CANCEL button twice to clear it.
The only way to fix the problem is by replacing the door lock/switch assembly with part numer 8181700 and costs about $40-$55. Some vendors listed it as part number 1094190 or PS972231. Below is the replacement procedure.
Door Lock/Switch Replacement Procedure
  1. Unplug the machine and open the door.
  2. Stretch the retainer spring of the seal boot retaining hoop then remove it. The seal boot is the gray rubber around the door opening. The retaining spring is located at the bottom of the door opening. The door lock/switch assembly is located on the right side of the door opening.
  3. Ease the part of the seal boot off the lip of the door opening near the door lock/switch assembly. Remove enough of the seal boot to gain access to the door lock/switch assembly behind the front panel of the washer. Be careful not to tear the seal boot because it will cause water to leak from the tub.
  4. Remove the three screws securing the door lock/switch assembly to the front panel.
  5. Lift the door lock/switch assembly and pull it away from the front panel then pull it out of the machine.
  6. Disconnect the wiring harness connector and connect the new door lock/switch assembly.
  7. Reinstall the new door lock/switch assembly and the seal boot in reverse order of the procedure above.
Jan 20, 2010 | Whirlpool GHW9150 Duet Washer
My machine wont start ,unless i really have to slam the door real
Either the switch striker/actuator on the door is worn or the door lock/switch assembly on the right side of the door opening is faulty. It is recommended to replace both parts when one is faulty or worn. The door lock/switch assembly is part number 1094190 and costs about $55. The switch striker/actuator is part number 906446 and costs about $5.
  • Unplug the machine.
  • Open the machine's door.
  • Locate the retainer spring of the seal boot retaining hoop at the bottom of the door opening.
  • Stretch the retainer spring apart then remove the retaining hoop.
  • Ease the edge of the seal boot off the lip of the door opening near the door lock/switch assembly. Remove enough of the seal boot to gain access to the door lock/switch assembly behind the front panel of the washer. Be careful not to tear the seal boot. It will cause water to leak out of the machine.
  • Remove the three screws securing the door lock/switch assembly to the front panel.
  • Slightly lift the door lock/switch assembly, pull it away from the front panel then pull it out of the machine.
  • Disconnect the wiring harness and connect the new door lock/switch assembly.
  • Reinstall the new door lock/switch assembly and the seal boot in reverse order of the procedure above.
Jan 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hi, I have the same problem on my Whirlpool Duet GHW9100LQ1.
The following link explains how to replace the bellow on a Whirpool Duet:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
The part number for the bellow is 8181850.
Searspartdirect.com carries it for about $81.
Appliancepartspros.com carries it for about $76.
Repairclinic.com carries it for $95.
Pcappliancerepair.com carries it for about $73.
Two other items you may also consider are the bellow clamps (if yours are damaged). The rear bellow clamp part number is 8182210. The front bellow clamp part number is 8182211.
If you have any questions about this repair, or require additional assistance, please let me know. I hope this helps you.
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GHW9100LW@ whirlpool Duet grey seal leaks
Here's the instructions you need to replace the door bellow on a Whirlpool Duet:
Let me know if you need further assistance. I hope this helps you.
PS I know it's a lengthy read, but it's a simple repair if you follow the directions.
Jun 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaky Door Seal
You can follow this link for step-by-step instructions on how to replace the door bellow:
I hope this is the information you needed. If you have questions, please post back and let me know.
May 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaky Door Seal
This is a very hard job for a tech to do mustless explain there is a spring that holds the door boot to the front of the machine and a very large clamp that holds it to the tub
May 21, 2008 | Whirlpool GHW9300 Duet Washer
Rubber door seal rip...
The rubber door boot (bellow) commonly wears out on these front loaders. A replacement will run you about $80 just for the bellow. Labor could run as high as $180 if you decide to hire someone to replace it for you. If you wish to perform the repairs yourself, post back with your intentions and I can provide you with step-by-step instructions on how to replace it. It is labor intensive as you will have to remove the entire washer front in order to do the job right. It IS possible, however, if you wish to pursue a repair option on your own. Just let me know.
PS I can also provide you with the part number if you reply with your washer model number (found along the door opening).
Nov 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
181 people viewed this question
Dan Webster
Dan Webster
Sal De
