Question about Poulan Garden
How to repair a poulan pp 136 trimmer? The rope to start won't rewind.
  • 120 Answers
Most likely you have a broken return spring.whitch will involve removing the blower cover and putting in a new spring,and then reloading the tensionon it.there is trick to that but its hard to explain....you have to tuirn the rope holder the oppisite direction you want it to pull the rope in ,then you feed in the rope while holding the spring loaded then tie the string in and let go...Normally 4-5 rounds will do for a good recoil..Hope it helps
Posted on Aug 28, 2010
How do I replace the pull starter cord
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starter Repair
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
Apr 01, 2016 | Garden
Rewind starter cord
How To: Rewind a Recoil Rope (Fix a Broken ... - YouTube
? 2:52
https://www.youtube.com/watch?v=J0KJuqsJJ_k
Feb 16, 2012 - Uploaded by Champion Power Equipment
How To: Rewind a Recoil Rope (Fix a Broken Recoil Rope) .... Back off until rope hole in pulley lines up ...
How to Repair a Small Engine Recoil Starter - YouTube
? 4:49
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jul 15, 2011 - Uploaded by eReplacementParts.com
How to Repair a Small Engine Recoil Starter ... Would like to now use the pull cord on the mower but it won ...
Nov 28, 2015 | Garden
Poulan lawn mower cord won't retract
New or used unit? If new can you return it ? If not you will need to take the recoil assembly off the engine and rewind the spring. Check inside the recoil assembly to see if the spring is broken or just popped out of place on either end. If it is broken your done. You will need to find a Poulan dealer to get a new spring. If new take it to a Poulan dealer for warrenty replacement. If you want to try to rewind the spring look to see where one end of the spring fits into the housing and the other into the spool. On the edge of the puley should be a notch. Place the rope in the notch and turn the pulley it in the direction needed to wind the spring about 4 or 5 turns. If it now pulls all the rope in you are done.If not put the rope back in the notch and wind the spring tighter till the rope is all pulled in.
Jul 25, 2013 | Garden
Repair weed eater
just apply some oil to the mech.
Jun 05, 2013 | Poulan Garden
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I have a Poulan PRO LINK PP 335 and the pull rope is only coming out about 8 inches. It's stuck...what should I do?
Remove the starter and pull the cord, if the cord still only comes out so far it is either the cord is too short ( replace the cord ) or the rewind spring is coil bound ( release some of the tention )
Apr 23, 2011 | Poulan Garden
How do I replace the pull rope on the TE 475 weedeater? I went to start it today and pulled on the rope and it all came out.
How do I replace my pull cord on my weed eater TE 475? I have the parts diagram, I need to know where the cord attaches and what the steps are to rewind the pulley and attach the cord.
Oct 19, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Pull Cord Will Only Pull Out 3-4 Inches Then Sticks
Take it apart as you did before. Look for whatever it is binding. Did you rewind the rope so there is a good amount of tension? If you didn't, then do that . Good luck, Lee
Sep 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Rewind don't work
as you put the side with the recoil starter back on the saw, ensure the rewind pack isn't binding. before tightening the screws, pull the rope out a few inches and let it rewind. if it won't, something is binding. keep moving the side panel till it will rewind. I have done this before myself. get it all put back together and it won't work.....
Jan 29, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
91 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
