Question about Refrigerators
Ge freezer problems
I have a GE side x side that is about 6 years old, model GSS25LGMA CC. The ice in the ice bin has begun to stick together and there is frost on the ice and in the bins. My tech hase replace the mother board with no luck. What shoulld I try next?
  • vsblackwell Aug 03, 2008
    I have the same problem... It seems like the ice freezes and then starts to melt and refreezes. I ve also notice that the food in the freeze has frost on it.
    Genius:
  • 1,073 Answers
Check the defrost heater it could be bad if it is good change the sensor on the top of the evaperator coil it is white and about 1 inch long, has white wires connected to it
Posted on May 06, 2008
Our GE Adora Refrigerator's ice maker isn't working properly
Perhaps your freezer isn't set cold enough - or your freezer door seal is not sealing correctly and the ice cubes are melting in the bin and sticking to one another and the spiral screw that delivers the ice.
Mar 14, 2010 | GE Adora (DSF25KGTBG) Side by Side...
GE Side By Side refrigerator. Freezer melts ice together
Call GE since this refrig is still under warranty . But , you should turn your freezer to 0 degrees first .
Jan 28, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
I am having froozen food in the refrig. GSS25LGMA CC side. Temperature control has no effect on changing setpoint control.
THE MOTORIZED DAMPER IN THE UPPER LEFT OF THE FRESH-FOOD SECTION OFTEN STICKS OPEN ALLOWING AIR TO SEEP IN FROM THE FREEZER IF THIS IS THE CASE YOU NEED TO REPLACE THE DAMPER ***.
Jan 11, 2010 | GE GSS25LGM Side by Side Refrigerator
GE Adora Side by Side Refrigerator Ice maker
You may ahve a problem with your freezer temp. Check your setting. Turn down a few notches to see if problem goes away. Also Pull out your fridge and vacuum out your coils underneath unit. Plug coil causes freezer temp to rise. Rus
Jul 04, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Apr 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
The ice maker (GE Profile - 3 years old) produces ice and then, the next morning, the ice melts down into the rest of the freezer (i.e. the ice compartment is somehow not staying cold enough to sustain any...
If the unit is freezing well in the freezer and your ice bin is defrosting or ice is melting together it is your ice maker over filling the tray causing water to leak into the bin. You can purchase kits that contain all ice maker parts needed , it may be the ice maker and it may be the water inlet valve in the back , both come in the kit , go to sears parts on line with the model number from your unit.
Dec 30, 2008 | Refrigerators
GE Side by Side Ref
Sounds like an internal mounting spring for the compressor. Only solution is replacing the compressor. However the compressor can run in this condition for years. Replacement compressors only have a one year warranty. A new refrigerator comes with a five year warranty.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Food freezing in frig
Go to the link below and the choose line 22 and click it. That link page helps identify most common problems you may have with your refrigerator, Thanks Sea Breeze.
 http://www.applianceaid.com/refrigerator.html
Sep 11, 2007 | GE Profile PSI23NCR Side by Side...
Refrigerators Logo
153 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
