Question about Sony Playstation 3 (PS3) Console
Error code 80010516 for my ps3 what can I do - Sony Playstation 3 (PS3) Console
Well, last night i bought FF13 and about halfway through the game i saved and then the game froze. after that it wouldnt read anything, even regular dvds. We called Sony twice and they only said to pay $150 to fix the problem, they gave us no other advice. we have tried everything you can possibly think of, re-formatting the hard drive to scanning for corrupted files, nothing works. we decided to try one more time this morning after leaving the ps3 off all night, we put LBP in and an eror code popped up on the screen "80010516" is there anyway to repair this so i dont have to pay $150-399 for a new ps3??
Posted on Nov 04, 2010
How do i fix ps3 error codes
the sony knoledge center on the web has a list of all the error codes and how to solve them
Dec 07, 2014 | Sony Playstation 3 (PS3) Console
PS3 not reading disk. Error code 80010516
I started getting this code after playing COD MW3 after a while of playing. PSN swore it wasn't caused by the game, but it is your blue ray disk drive that is bad. If you send it to them under warranty, they will fix it for free. If it is out of warranty, it will cost you $105.00 for them to fix it. You will have to go to PSN and log in and request a service repair. They will send you the packing stuff and ship it for free. It will only take about 2 weeks to get it back, but they will go over the system, and replace every component, so you'll basically get back a new system.
Mar 30, 2013 | Sony Playstation 3 (PS3) Console
Ps3 error code 80010516
Step 1:
7 times out of 10 you can clean your blu ray lens with a q-tip and alcohol, but you'll have to open up your ps3. You need to becareful not to mess any wires up. You can youtube how to open it on youtube
Step 2:
This is the procedure for a phat ps3.
remove the warranty sticker and pull the rubber plug out. Remove the screw which is a octagon looking one
Step 3:
Once removed then slide the top towards the way the screw was removed. pull off the top.
Step 4:
Now you see arrows pointing to the screws you need to remove next. The rest of the screws are Phillips.
Step 5:
After you remove all those screws on the back right corner, press the plastic latch in as you remove the top from back to front. Note...lift the back up in a tilting kind of way. So you can remove your ribbons.
Step 6:
to remove your ribbons, flip the connector latch up. Now you can see your Blu-ray.
Step 7:
unplug the white cord from the side and make sure you don't rip the ribbon connected to the bottom of the blu ray. unhook that ribbon from the blu ray.
Step 8:
Next you need a little Phillips screw driver to take the case off the blu ray. remove case. Then lift the white magnet up and clean your lens with a q tip. Reverse steps to assembly your ps3
I have an error code in the install operation tell me how to fix it
Common PS3 Error Codes and required Network Ports.
Additional PS3 Error Codes:
80010514 - Dead BD lens.
80010516 - Dead BD lens (happens at different occasions, code above is more common).
80710092 - Connection error (usually the connection is dropped), you will be signed out of PSN.
8002AD23 - Unidentified error (cause unknown), happens in Burnout Paradise (when game starts) and sometimes SARPBC.
8002A227 - PSN account suspended.
8002A212 - error returned by the PSN servers during authentication (invalid version).
80029945 - Can't playback burn BDr movie (error in picture above)
80029946 - Attempting to play burnt Dual layer NTSC disc on a Pal ps3
(workarouns is to transfer files to ps3 via TVersity)
(added 24th Sept 2007)
80029301 - An error occurred during the delete operation (attempting to delete some ps2 homebrew from virtual mem card) (added 15sept2007)
80029516 - Sign in to PLAYSTATION-Network (needed for some games or Ps3 processes - have to sign in to use them) (added 04-sept-2007)
80710A06 - An error occurred during the install operation (error when downloading game from PSN - network error occured (added 30thAug2007)
8003041F - An error occurred during the copy operation (using media server) (added27aug2007)
80010006 - An error occurred during the start operation (added 22aug07 - corrupted folding install)
80010007 - An error occurred during the start operation (added 17aug07 - during disc swap tests)
710102 - DNS Error; No DSN server available.
8013030 - System Error due to failed update download
80010001 - Major Error , Game ability stopped
80010017 - Can't start Blu-ray Game
80010510 - Will not play hard drive games - Cause unknown
80010516 - An error occured during the start operation; Ps1 game swapped using the eject function and then play pressed quickly - ps1 game inserted again
80029023 - Exchanging Key Information exchange has timed out
80029024 - "Cannot Obtain an IP address".
80029564 - Downloaded Game will not install - Cause unknown
80030920 - An error occurred during the copy operation. The file may be corrupt or there isnt enough memory. Try copying data from original source.
80031150 - System Settings Fail to Save - Possible Blue Screen "Setting information is corrupted.Pre
80031601 - Error Creating Account
80130203 - PS3 connects to internet but not to network - Typically means that the required ports are
80410418 - DNS Error
80710016 - Playstation Network is down.
80710092 - "An error has occured. you've been signed out from the ps network" -(connection dropped?
80710101 - Conneciton error
80710102 - IP conflict , PS3 Cannot connect to the router with current IP information - Try rebooting your router
80710541 - The connection to the server timed out. press the x button to repair and restore default"
80710723 - Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ
81019002 - Error copying saves from location A to location B not open to connect to store but PS3 can connect to internet.
8001050B - Will not play demo hard drive games, when blue-ray disc is inserted - Cause unknown
8001050D - An error occured during the start operation; Ps3 game swapped using the eject function and then play pressed quickly - ps3 game inserted again
80028EA5 - Unknown?? User cannot connect to PS3 network. Sony told the user to send the machine in.
80028ea6 - Connection error , Possible Proxy error power cord. Then shut off your modem/router, for about 5 mintues, then turn the modem back up first and let it sync, then turn the router back on(if using one) and let it sycn.
Reconnect your power cable and flip the back swtich up again. Then make a new network connnection.
80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automactic,
80028f17 - Ps2 disc Boot Error , An error occured during the start operation; Ps2 game swapped using the eject function and then play pressed quickly -Backup ps2 game inserted again
80028F18 - Ps2 Disc Error, unsupported disc; eg. Utility discs, BB discs, IQ Remix game etc. ode).
80028F19 - PS2 Disc Error , fsck; the internal PS2 disk got corrupted and I guess that you can use HDD utility disc to fix it
80028F1A - Ps2 Disc Error , invalbnnetcfg; network config error
80029C68 - Corrupt data usually on external device
8002A10D - Unable to Add friend in XMB
8002A4A6 - Cannot load game to play online
8002A515 - Error Signing in
8002A548 - Unable to remain logged in - either to game or server
8002A705 - Unable to connect to server/host. Check router port configuration.
8002a71a - Possible NAT Error , Can log onto Game Server but can't join game and can't host game
8002b241 - DVI has no audio
8002F994 - To many people downloading the update just sit back until the morning around 5am - 11am and you should be able to get it.
8002F997 - Trying to Update the Firmware, copying to a file and installing from a USB drive falied".
8003051E - Game will not Save
8013013D - "A connection error has occurred" - May be to do with the SSID of the Router or signal strength if the conneciton drops Putting the PS3 into DMZ may help - otherwise check WPA key Ps3 can't handle WPA2 only
WPA or none
8013013E - WEP Key error, change WEP key to all numbers (on router homepage) and try agian, or which to WPA. - Otherwise disable security
8013030F - Check Router Page, SSID Broadcasting possibly off.
8013030F - Access Point not detected
80410A0B - Internal PSP error, hardware fault. Send back to be replaced/fixed.
807101FF - An error occurred during communication with the server. This is a DNS error This is a DNS error
8071053D - Hard boot the PS3, turn off the PS3 to stand-by, flip off the back swtich and remove the
80710B23 - PS3 Network is Down or PS3 Network is too busy to respond
80710D23 - Turn the PS3 off for a bit (30 minutes give or take) with the power toggle (not standby mode)
80029513 - Copyright Violation when attempting to install game
8003200D - Server side issue, much like the trophy syncing problems.
8001050F - System Clock Error.
8002A227 - You account has been banned, either temporary or permanently, (Check here for reason why you may have been banned).
80029780 - Unable To Activate System - You have reached the maximum downloads for an unactivated system. This will not affect systems that are already activated on your PSN account.
80010002 Invalid argument.
80010003 Invalid syscall number. A lot of the addresses in the syscall table at 0x2EB128 point to a function that only returns this value.
80010009 Operation not permitted.
8001002B Filesystem mounting failed.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
When i go on the game it always has a tick on a ps3 and the game doesnt load up and it says (80010516)
Most of the time this error is caused because you eject games while they are being used. To solve this error try the following in order, one by one, until your problem is solved.
1) Turn your console off using the switch in the back.
2) Delete all your messages.
3) Clean the disc for the game that is causing the error.
4) Upgrade your PS3 Firmware.
5) Turn "PS/PS2 upscaler" off.
If not of that works, your disc is broken.
Mar 10, 2011 | Sony Playstation 3 (PS3) Console
How can i fix error 80010516?
If you have the latest firmware. there is a recovery option on the new set that allows you to go back. I had the same issue with my PS3 and it was actually just because the Disc i was using was bad/defective and caused a whole slew of problems. I actually reverted back an update and it fixed the problem.
Hopefully that helps!
Mar 01, 2011 | Sony Playstation 3 (PS3) Console
I got an error on the PS3- 80010516, what is it ?
This is the meaning of the code:
80010516 - An error occurred during the start operation; Ps1 game swapped using the eject function and then play pressed quickly - ps1 game inserted again.
Thank you and good luck!
Apr 25, 2010 | Sony Playstation 3 (PS3) Console
Won't read games-any bluray
Usually 80010516 = An error occured during the start operation; PS One game swapped using the eject function and then play pressed quickly, PS One game inserted again.
Well there are only two things that can be done.
1.) Check to make sure the disk is clean, as well as the PS3 vents.
2.) Get a cleaning disk to clean the lens.
If those to do not work you may want to try saving all of your game saves and anything you want to save and do a full system restore (format) IF nothing then, call Sony to have the lens replaced.
If you want you could do this your self. Many online manuals to how to take apart the PS3 and clean the lens.
Jan 26, 2009 | Sony Playstation 3 (PS3) Console
Error code 80010516
Turned it on and off 3 times in a row. Worked like a champ after that!
Jan 07, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
667 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
