My frigidaire fwfb9200es won't spin. The guy at the appliance store said that there should be a manual that would tell us some buttons to push to diagnose it, but we cna't find the manual. Any ideas?
4 Suggested Answers
  • 43 Answers
SOURCE: my bosch wfe2021gb won;t spin. how do i diagnose
Try a spin when empty if it spins ok the brushes are wearing on the motor
Posted on Jun 26, 2010
  • 489 Answers
SOURCE: The drum won't tumble until you spin it
You have a broken centrifugal switch on the motor. The motor needs to be replaced.
Posted on Jun 16, 2011
heatman101
  • 43501 Answers
SOURCE: AEQ6000ESO frigidaire dryer won't start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 12, 2011
Fridgedaire front loader only goes into High spin with a light load.heavy load won't go into High spin
Product Support & Manuals - Frigidaire
www.frigidaire.com/Owner-Center/Product-Support-Manuals/
FrigidaireFind appliance guides and manuals, FAQs, information about accessories and more. Get all of the answers you need about your Frigidaire appliance today.‎Dishwashers - ‎Ranges - ‎Window Mounted Air ... - ‎Washers
Sep 10, 2015 | Washing Machines
Why wont my washer to perform the system clean cycle?
Hello Larry Occhipinti, thank you for your post!
If you are pushing the necessary buttons on your Frigidaire washer to perform a system clean and they are not working, it could be a possible issue within the control panel. I would recommend a reset on your appliance which can be done by disconnecting power from your appliance for roughly ten minutes. If that does not correct the issue, you can run a hot water wash cycle with a cup of bleach inside the tub to clean your appliance out as well. I hope this is helpful. -Matt
Aug 31, 2014 | Frigidaire Affinity ATF7000E Front Load...
Good evening, My Roper washer RAX4232PQ0 will not spin...it seems to drain OK but won't spin...can you offer any help? Thanks!
I am thinking if all works good except won't spin, it is your lid switch. Under your washer lid you will notice a peg of some sort that when lidnis closed goes into a slot/hole and that triggers the spin cycle. That is in lamens terms know as a safety idiot switch. It is designed so when the washer is spinning at those high speeds,na child or not to smart adult does not open lid and put hand in while spinning. SO, if switch goes out, of course it won't spin. Switch is cheap , under 20 bucks at any appliance parts store, and they even can tell you at store how to putnin yourself by showing on one of there washers on display. Let me know if I nailed it!! Thanks Mike
Jun 09, 2011 | Roper RAX4233PQ Top Load Washer
Were is water filter in refrigerator
The water filter is located inside the fresh food section. In the top right hand up front as soon as you open the door it has a push button to eject the cartridge or it is in the back of fridge section in a plastic cup that easily unscrews. A new filter can be purchased at a hardware store or local appliance repair store. they can also be ordered online.
Oct 26, 2010 | Frigidaire FRS6R5EMB Side by Side...
The e68 keeps popping up on my time window. Have
You can contact this guy...seems others have had the same problem with some frequency..send him your contact information...model and serial number...he's THE guy to talk to with Frigidaire. Chris Polk
Escalation Specialist
electrolux Major Appliances
chris.polk@electrolux.com Another tech had this information to share: 6 beeps / E68 - Push button does not function
Cause:
Push button held too long or wedged in the control panel.
Solution:
Press buttons lightly and release.
Disengage button.
Try doing that first if the error code still shows up, then you'll likely need a new control board assembly.
Here's the one for your model:
Manufacturer part#134523200 is RepairClinic item#1154933
May 02, 2009 | Frigidaire Dryers
Frigidaire washer won't agitate
hi Cinebar.
this is what i found from the internet so not sure if this will be off help to you.
There could be several reasons why your Frigidaire washer will not agitate, including problems with the power supply, the wash cycle or the way in which the appliance was loaded. It is a good idea to try to resolve the problem with your washer yourself first since unnecessary repair call-outs can potentially be expensive if your appliance is outside its warranty period. Troubleshooting your Frigidaire washing machine will take about 15 minutes.
Confirm the water shutoff valves are open. If your Frigidaire washer cannot draw water from the pipes, it will not fill or agitate. The shutoff valves are usually located behind the washing machine where the water pipes meet the wall. Allow the washing machine to cool down for 30 minutes. Frigidaire appliances automatically shut off if the motor starts to overheat. The cool-down period lasts for half an hour if the appliance has not been switched off manually.
Verify that the detergent draw is tightly closed. If the dispenser is left open, the washer will not start or agitate its load. Push the draw so it sits flush with the front of the washing machine.
Ensure that the washing machine door is closed. As with the detergent door, the appliance will not start if the door is left slightly open, to prevent water from spilling onto the floor. Push the door closed until it clicks, and try your load again.
Confirm that your Frigidaire dryer is set to a spin cycle. If your dryer is set to a soak cycle or is currently in the soak portion of a longer cycle, it will not spin or agitate the wash. Make sure the appliance is set to a spin load and try again.
Contact Frigidaire if problems continue. You may be entitled to free service if your washing machine is within its warranty period. See Resources for Frigidaire's contact information.
or read up more at this link.
Frigidaire washer won agitate Google Search
Dec 11, 2017 | Frigidaire GLWS1649A Top Load Washer
Frigidaire GLTF1670ASO is cycling fast and not spinning
Hi , try to check timer small motor .,also available in appliances store.
Feb 15, 2008 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
123 people viewed this question
Top Washing Machines Experts
