Question about Fujitsu Heating & Cooling
I have a Fujitsu split air conditioner AOT24RNCL. The cooling, dry and fan settings are working. When I change to heating the unit trips the electric switch which is located at the power board. Any suggestions
    Problem Solver:
  • 19 Answers
You have a short in the heating element. This could be something in the heating element that is conductive and needs to be removed or the element is touching the case or side of the unit. WARNING make sure power is off as the heating element is electricaly charged befor you try any repairs.
Posted on Aug 28, 2010
3 split units run from one compressor one is not cooling
If there is 3 indoor units from one condensing unit
(6 pipes at outdoor unit) this is classed as a multi unit
All units will run correctly as long as they all require same mode, cooling or heating, if one unit decides to heat it will shut down until master unit decides to heat then it will start, for each unit to individually heat and cool there would have to be 3 pipes to each indoor,
Dec 19, 2015 | Fujitsu 9RLS 9000 BTU Split System Air...
We bought a house with Fujitsu Air-conditioners we have no instruction manual on how to use the remote. Im trying to set it to go off after an hour or so. Model No.INDOOR UNIT is, AST12RSJCW Serial No is...
Switch on by pressing ON/OFF. Press mode button to cool position. for cool and keep required temp by clicking
Same procedure for Heat. For heat keep +29 and for cool 25 to 22 degree. Press fan for High, Med,Low. If you keep mode in Auto cool and the fan speed will be low and you can't change fan speed.
Please visit Fujitsu website for further details. Hope my msg is helpful?
Dec 09, 2010 | Fujitsu Heating & Cooling
We just moved into a rental. It has the Fugitsu wall-mounted Air-conditioner model: ar-jw2 but, there was no manual left behind and we are trying to use the heat, however, it just blows cool air, we're not...
Look, if you select a temperature above ambient temperature, it will switch from cooling to heating.(assuming that the aircon has a heat pump. most do these days.) Just dont rush the aircon because every time you make a setting change, it takes a while to regulate.
Aug 12, 2010 | Heating & Cooling
Fujitsu Air Conditioning split unit Model
Your compressor is seized up. shut down unit and let compressor cool down, it may start again but probably needs to be replaced.... sorry for the bad news,
Nov 10, 2009 | Fujitsu 24C1 Air Conditioner
Split unit, I get heat but no cold
I have run into this with the LG brand systems. try shutting power off to the outdoor unit to reset all units. If problem persists, it could have to do with a charge level of refrigerant (freon) or possibly a failed control board.
May 16, 2009 | Fujitsu 24R1 Air Conditioner
Fujitsu heat pump noise
i would check the blades on the condenser fan motor and make sure they are not hitting anything if they are not, spin the fan see if the fan spin freely, it should, if it doesn't it could be the bearing in the motor are dry and going bad
Jan 22, 2009 | Fujitsu 24C1 Air Conditioner
Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Jun 07, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
197 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
